8 members (66flea, asilverblazer, J Lucas, Otto Skorzeny, tclederman, Hotrod Lincoln, klhansen, 1 invisible), 136 guests, and 3 robots.
Topics128,185
Posts1,057,294
Members48,467
Page 16 of 177 1 2 … 14 15 16 17 18 … 176 177
I finally got to prime the inside of the cab. Ground down the ugly welds, cleaned to metal, Phosphoric acid, Por-15 in seams and areas that had rusted and shot it with PPG epoxy. Now I get to fill the repairs to the dash and sand some more. At least it is primed for the winter. primed inside
Let's see, from Friday afternoon at 6:00 to Monday night at 10:00, that's what, 76 hours?
What all did you get done? Did you use the time wisely?
~Jim
I wish! I'm still on the disabled list so I'll mostly sit and browse the Internet and maybe get out for some exercise by walking a car show.
I hope everyone else is able to be more productive!
Same here, sort of. My truck is in the paint shop. While the cab interior has been painted, my steer column needs to be removed and painted, and the exterior as well. The fenders and running board has been painted (a dark-dark shade of green that blends with the lighter metallic green cab, hood, and bedsides.
The bedsides are home in the garage. I have sanded the wood and will be having the shop shoot it with a clear coat. I can't put the bed together until I have the truck. I can't get the truck back here until the painting is finished and we take it to the upholstery shop for the seat, headliner, door and kick panels.
~Jim
put the rubber strips between the body and running boards on my panel... then put the running boards on...then finished up the serpentine system.... all but the tensioner that the powder coated still has and I made aluminum brackets to fasten my electric fan to the radiator collar...then mounted the radiator/fan assembly to the chassis.
...also replace 4 ballast that had went bad in my shop lights, cut grass and weed eat, watered garden, cut shurbery, and got all ready for the Southern Stovebolt reunion which is TOMORROW.
Oh, I forgot about having some gret BBQ with a Bolter tonight.
School is OUT... more Panel time, Yipeeee
Heck, I'll be working ground and trying to sell my cutlass. Also helping my son build a rocket for 4-H.
Should have some time at night to do brake work on my '62.
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
Now that I'm driving her almost every day ,I got some things to adjust ,like the clutch ,center the wheel ,got the wheel aliment done ,change the oil and filter ,regrease every thing,I washed and waxed her last weekend ,than go down the street and help My buddy get his 49-3100 put back together ,We just got her back from paint ,Frist Wedsday in June is a classic car show here in the town next to Me Bensinville Il. thats going to be the frist one for My Wife and I and the 52 thats what the kids call her ,so We're going to throw a couple of lawn chairs in the back of the truck and have some fun ,they have a band there at the show .
Thanks to all the sevice Men and Women for keeping us free to build Our trucks and live the good life.
Pete
Finishing plans for new garage - tall enough for a lift. Finally I'll get to see the bottom of this truck - up close and personal..
Installed a SM420 4-speed (with 3,000 miles on it) in the 54 Suburban. Thanks to Bruce Bugay, I had a NORS u-joint for the enclosed driveshaft, and a NOS drive gear & driven gear for the speedometer (and the torque-tube rear cover from another stovebolter - but I forget who - sorry).
Went for a cruise yesterday and it seems to be OK. Macungie, here I come.
Village Memorial Day Parade on Monday - friends my age who served are marching (as are some of their sons and daughters who have served during the past 12 years).
If you count Friday, I got my doors hung for final fitting. So far on Saturday I cleaned my patio furniture... it's all I could manage in this stifling heat and un-announced thunderstorms.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Friday took the truck out to get some ice cream. Saturday took my recycling to the recycling center, stopped at Sonic Drive in for lunch, and picked up some flowers at soil at Home Depot. Used the truck as it was intended to be used and got some great waves and comments. Sunday plan on attending a weekly cruise-in.
Ex Hall Monitor
Ex Hall Monitor
I got some serious mechanical work done. I installed a rear end in my recliner.
I'm sure that wasn't a 9". lol
~Jim
I fabricated a bracket for my pedals to mount them to my T5 trans.... waiting for a nice big part order on tuesday
enjoy the weekend
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
I pulled the wheels off my front hubs to do an inspection on my '50 half ton.
I also thought it was a good time to grease the zirk fittings on the front end. Found out that several were bad......heck, their only 60 years old!! Decided while I was under there I'd check out the shocks because they looked pretty rough. The top and bottom nuts were really hard to get off. After spraying with WD-40 and PB blaster I thought I had the top nut off one of the shocks and then it happened.......the bolt twisted off. Well, the shock was bad after all so I didn't feel too bad. Took the other side off without incident. Went to Advanced, O'Reilly, Auto Zone and NAPA and none of them had shocks to fit in stock, so I ordered two for the front end and they will be in Sunday by noon, so I should have them installed soon after. I also bought some new zirk fittings and installed those. The grease gun worked perfectly and now the front is full of new grease.
I had fun today!
Spot
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Apprentice
Apprentice
I replaced the fuel filter assem with the original style glass bowl and made a new fuel line.well actually 2 fuel lines,i didnt like the first one. while i had the tubing bender out i made a new vacuum line too. looks good with nice clean bends.went to a cruise night friday with the truck. parked next to a 55 chevy with a big blower. funny my 6 banger got just as many looks.
tonight i had a BBQ and watched the hockey game.then discovered my carpet was soaked in my basement.so i will be replacing my water heater tomorrow instead of working on the truck.I still have monday after the parade.
55 stepside 3600
67 chevelle ss conv
joe
springfield,PA
Well, since this is General Truck Talk, and not the Greasy Spoon, I guess I should focus on what I got done with the Blue Funk, workwise. Friday, I took her to Jerseyville and bought a case of oil. That'll get me a couple hundred miles. Just kidding.
I then replenished my fuel supply with Belinda at a drive-in type of restaurant. (I've heard it said that Stovebolts run better on a full stomach.) We listened to Hank Williams on the two 4" speakers mounted in the radio grill. The audio test went fine.
I volunteered to work every weekend and holiday, so here I am. And there are you. Have a good one.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
On Thrusday, I got my truck back from the paint shop, so will spend the weekend putting trim back on, etc. So far I have the mirror, headlight brezels, grill, bumpers, hubcaps and insignias installed. Work to be done include installing a mirror on the right side, installing a visor on right side of cab (never had one) and installing the bedwood/strips. (The bedwood will be a next week product as waiting on parts from Mar-K) Like Alvin, I also got the normal yardwork to be done, so I'll be a 'busy beaver" this weekend!
On top of all of the above, I will pause to remember our Military and all they do to insure our freedom.
Thought I had the windshield and rear glass rubber replaced. Turned out the windshield will not go back in properly, and I cracked it doing so. (Searching here for a solution). But at least the rear window is back in nicely!
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
i got my truck running for the first time in 8 months. rebuilt the motor, tranny, dizy, starter and carb. i'm very happy.
i started stripping the cab. in a week or three i'll paint the cab.
Apprentice
Apprentice
Hi, my project is basket case 1953 GMC 5 window. I have inner fender painted and in process of installation, have radiator mounted, working on splash pan by sanding-painting and installation. did goof off on 4 wheeler in woods picking about 30 morrells. Raining today but will still work on 53.
I put a set of mud flaps on the '47, and did the annual topping off of the master cylinder with brake fluid.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
On Friday I finally finished the brake job on Lucille! New master cylinder, new wheel cylinders, new lined huck brake shoes, new hoses, new brass blocks, and shiny new stainless brake lines!! And with good advice given to me by "Achipmunk" I was able to safefully drive to the Southern Stovebolters Reunion in Spartanburg, SC! It such a great feeling knowing that now I have a safe truck to enjoy riding. Lucille has other issues still but the brake thing has haunted me for three years. I finally had to make the decision to redo the whole system. A nice end to what was a lengthy process for me.
BTW, from one Vietnam Veteran to all you Stovebolt Veterans....Happy Veterans Day!! Remember...Some gave all...All gave some!
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
.... don't let him mislead you. Lucille is one fine looking truck.
And yes, thanks to ALL our veterans. Well said David.
Got my truck on the road for the first time!
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
rat fink, I see you did your "effective leadership is putting first things first"....way to go. Congratulations. Now I need to try that "first things first" on my wife. Honey, the panel needs .......
I finally diagnosed why I was getting bad starters. My hot battery cable was intermittently touching the exhaust manifold, causing a tiny short. But that's all it takes.
Then I set the valve clearances on my old BMW and pulled the head off my old Triumph to get started on several projects for it.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
thought i would tighten the vent glass adjustment nut on the 55-2 wife was not getting the air she wanted becuse the vent glass would not stay out ....so on the last turn of the adjustment nut under the spring , i dropped the 1/2 wrench down in the door ! bummer and spent the rest of the afternoon on and off in the heat getting the wrench out ...really don't think it was worth it !!!!
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
Yeah, tell your wife that. lol
~Jim
I got my 54 3100 home from the restorer, been 8 months since we started working on it. It looks good sitting in my garage.
I've finally the upgraded to rear discs. Had to change rearends (because I couldn't remove the spider gear pin out of the old one) and shorten the driveshaft and replace all the bearings along the way and removed a leaf to drop it just a bit but over all I think it looks pretty good. The discs are from a 98-02 LS1 & the rearend is an early 70's Camaro.
Got in my small cap distributor in the other day and installed it. Couldn't get it to start, found my tank full of water. :mad: Drained it but haven't had the chance to start it yet. It would be nice to finally get a chance to really drive this thing!! drive
Robert C.
I'm a Genius in the making.
1950 3600
Where are the pics?
~Jim
Hey same here just got my truck rims changed. Got fascinated with the new stylish rims which I purchased online. But I am happy about it. Waiting for some more accessories to be placed in my truck.
Wow! Ya'll sure did a lot of stuff to your bolts today. Makes me feel like a weasel cause I got my carb up and working. Can't wait to get more time to start replacing the rusty parts with good metal again. Thanks for the inspiration.
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off"
- General Colin Powell
Y
Y Offline
Installed split manifold on my 51 Burb with 61 235. I was hoping for more noise, running out thru 26" cherry bombs. Maybe need some 36" smittys? Could be my ears, last car I had with split manifold was back in 63, sure seemed louder?
If you want to post about working on your truck, do it here. If you want to post about doing something else, doing nothing or the weather, go to the Greasy Spoon.
Finished up painting the frame today. Hoping to get the new disk brakes and suspencion installed tomorrow. will be graet to get her back on its wheels
How about sending some pictures of your work so those that follow will get an idea of how it works?
~Jim
Had a computer crash, so I've been off for a week or so. computerdeath
Anyway, I changed the jets (62's to 60's) and to a cooler thermostat for our elevation/temps here, in prep for cruising at Hot August Nights here in Reno. thumbs_up
Found some Trans fittings and moved the braided line away from the header to help it stay cooler and for a neater appearance. Things went smoothly for a change and seemed to help.
Not a darn thing, but I have the rewiring kit staring me in the face. I don't know how long it will take and have shows every weekend. Maybe I will have to call on some friends to help
