7 members (Brian Moore, tclederman, Lightholder's Dad, jupitor, treegrower, GMCJammer51, J Lucas),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | Hi, I'm Kevin. I got a '51 3/4 ton chevy this past summer. I'm not a mechanic. It's in the garage, I have the bed off - down to the frame. Is there a better way to get rust off besides a wire brush on the end of a drill? Thanks K. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | sand blasting. check your yellow pages, sometimes monument companies (headstones) provide the service. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome Kevin. Your in good company. Lots of guya around here from Ilinois. I'm sure you will hook up with them along the way. Sounds like you have a good start on your project. Keep us posted and how about some pics when you can. | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Welcome to Stovebolt!wire brush worked for us!;-) Lots of work.Good luck! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Kevin,firstly welcome to the 'bolt. Certainly blasting is probably the best option,but at a price. You also have the logistical problem of getting the chassis to the sand blasters,unless you can find someone who does 'mobile' work. Then you've got the mess to contend with.  I,like Joy,did mine the hard way and have been pleased with the results,it's a dirty job....but someone's got to do it! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Kevin, welcome to the Stovebolt! For removing rust from the larger areas, I use a 3M rust/paint stripper wheel on a drill. They do a great job and they won't harm sheet metal. I like using a cheap drill that has high RPM. Since it is tough work for a drill, it is another reason to use a cheap one. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | If you go to any auctions, you can usually pick up used drills pretty cheap. A friend of mine picked up seven for me last fall at $2 apiece! I won't have to buy any for a long time! And best of all, I'm not tearing up my good drill! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If you go to any auctions, you can usually pick up used drills pretty cheap.I'm not tearing up my good drill! Rich, I agree, I 'killed' my good Bosch drill pretty quick..... The motor seemed good enough,it's just they don't like the side loads imposed on the chuck too much! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | From a fellow Illinoisan, and relatively new guy, WELCOME! This site is agreat place to learn and exprience! | | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | Sounds like I better keep going with the wire bruch. Thanks for all the suggestions. I would love to add a pic but don't seem to see how to here. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Look on the left side of this page for the image posting policy and read all about it. You have to load them on some other site like photobucket and post links here. | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i've been using an angle grinder with a wire brush as well as a 3m paint removing pad.
if you dont already have an angle grinder it may come in handy on some other project as well. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Look for sales on a good angle grinder. My Dewalt has done extremely well and taken a heck of a beating. I'm sure everone has their favorite brand as well.
Hank | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Welcome to the Bolt! I agree with Hank Dewalt is hard to beat. It takes a beating but keeps on truckin! I have a 4 1/2" Dewalt and a 6" Metabo. They're great with wire brush, cutting wheels, grinding discs, abrasive pads. I also purchased a air die grinder which is excellent for those hard to reach spots using a 2 or 3 inch stripper pad. 3M makes the pads but if you do a little looking you can find them at harbor freight or tool wholesale shops at quite a savings. Have fun and wear a dust mask! | | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | Hi, it's Kevin again. If I did it right here is a link to some pics. Note the last, my quesion is...do I need to take the frame all the way down to the "shiny metal" or just down to the 'black'? Here is the link http://pbckt.com/sZ.w1d Hope it works. | | | | | Joined: Dec 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 64 | Welcome brother. I would look into chemical strippers for that as well.
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Kevin, what are your plans for coating your frame? If I am going to be welding on an area I'll take it down to clean shiny metal, the mig doesn't like rust. Otherwise I use the wirebrush to clean off all the loose particals clean it and coat it with Por-15 (It likes seasoned metal the best) If you have the means sand or media blast will clean it up nicely. The path we choose is usually dictated by time, money and rescources and what we are able to do ourselves. I travel through the week with work so one the weekends I have to divide my time between family, farm chores and my truck. I have had mine a year now and slowly making progress. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Kevin, your link works fine. Nice truck BTW. Try and remove as much,if not all the original black paint. (It's tough stuff!) I then used POR Metal Ready which neutralises the rust and provides a good key for the top coat and as Gmans 46 already mentions it likes 'seasoned' metal. Here's a pic of my chassis after painting. I brush painted and was more than happy with the results! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | That's a nice looking truck! Did it run and drive when you bought it? Looks to be a great find. | | |
