Brrrr
place holder
4 members (Shade Baby, Oswald, Sjm, Phak1), 157 guests, and 4 robots.
Topics128,271
Posts1,058,417
Members48,485
#601291 12/15/2009 12:55 AM
I think this is the right forum I made some gas tanks yes that is tanks as in 2, for my 38 GMC. They are going under the cab/bed between the frame. They are simple boxes 36"x12"x9" 16 gauge cold rolled steel with 2 baffles I welded them with a wire feed welder did an ok job but I do have a few pin holes plus it was suggested to me to use a gas tank sealer even if I didn't have any holes, so here is the question where do I get a good gas tank sealer would a parts house carry any.
One more question are the GMC gas gauge sending units the same as the Chevy ones in size I am assuming they are because Almost everything else is interchangable
1938 Gmc 1/2 ton
TheShoer #601293 12/15/2009 12:58 AM
I've used a white milky looking gas tank sealer from Eastwood to seal leaky floats and float bowls, works well for me.
Also check out POR15, think I remember reading something about a system they sell?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #601319 12/15/2009 3:05 AM
I just used Red-Kote in my tank last week. Available locally at parts stores.
Cletis #601339 12/15/2009 3:49 AM
... .and I have used the POR15 kit with complete sucess going on 10 years.
POR 15 has a good one check it out online. Use code hmn1209 and save 10% before the first of the year.
1951 restoration on website
http://www.hanklong.com
Riding in the Passing Lane
I wouldn't put any thing like that in a new tank. If it starts coming loose the thing is ruined. Couldn't you pressure test it & go over any leaks.
1972 Chevy c10 Cheyenne Super
Year ago I had a BAD experience with the EASTWOOD product. It started to peel off and and plugged up the pick up tube in the tank. I thought I had followed the directions in the kit, but I will NEVER use that product again.
It may have been a reaction to the ETHONAL fuel, I do not know. I ended using an NOS tank I found.
John Gott
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
J Gott #607100 01/04/2010 6:18 PM
In my humble opinion you should never put anything in a gas tank except gas. I have had a number of bad experiences with different sealers coming loose in tanks and clogging the fuel system. One of these experiences was with a homebuilt airplane where the builder sloshed the inside of the tank with sealer and it came loose and caused an engine failure resulting in a forced landing. (No one hurt). I suggest welding up the pinholes and forget the sealer. Just my 2 cents worth.
Weeds
Weeds #607130 01/04/2010 8:43 PM
Thanks for this discussion.
I plan to get the saddle tank from the 48 3100 boiled out at a radiator shop.
Weeds - you would not have this sealed?
Dennis
