7 members (Shade Baby, Lightholder's Dad, DoubleB, Oswald, Sjm, Phak1, 1 invisible),
131
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I think this is the right forum I made some gas tanks yes that is tanks as in 2, for my 38 GMC. They are going under the cab/bed between the frame. They are simple boxes 36"x12"x9" 16 gauge cold rolled steel with 2 baffles I welded them with a wire feed welder did an ok job but I do have a few pin holes plus it was suggested to me to use a gas tank sealer even if I didn't have any holes, so here is the question where do I get a good gas tank sealer would a parts house carry any.
One more question are the GMC gas gauge sending units the same as the Chevy ones in size I am assuming they are because Almost everything else is interchangable
1938 Gmc 1/2 ton
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used a white milky looking gas tank sealer from Eastwood to seal leaky floats and float bowls, works well for me.
Also check out POR15, think I remember reading something about a system they sell?
Grigg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just used Red-Kote in my tank last week. Available locally at parts stores. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ... .and I have used the POR15 kit with complete sucess going on 10 years. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | POR 15 has a good one check it out online. Use code hmn1209 and save 10% before the first of the year. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I wouldn't put any thing like that in a new tank. If it starts coming loose the thing is ruined. Couldn't you pressure test it & go over any leaks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Year ago I had a BAD experience with the EASTWOOD product. It started to peel off and and plugged up the pick up tube in the tank. I thought I had followed the directions in the kit, but I will NEVER use that product again. It may have been a reaction to the ETHONAL fuel, I do not know. I ended using an NOS tank I found.
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | In my humble opinion you should never put anything in a gas tank except gas. I have had a number of bad experiences with different sealers coming loose in tanks and clogging the fuel system. One of these experiences was with a homebuilt airplane where the builder sloshed the inside of the tank with sealer and it came loose and caused an engine failure resulting in a forced landing. (No one hurt). I suggest welding up the pinholes and forget the sealer. Just my 2 cents worth.
Weeds | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for this discussion.
I plan to get the saddle tank from the 48 3100 boiled out at a radiator shop.
Weeds - you would not have this sealed?
Dennis -there is nothing stronger than the heart of a volunteer-
