| | | Forums66 Topics128,094 Posts1,056,155 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | Hi I have a 57 6100 with a 283 in it and I was wondering what does the original 283 Look like and what options did they have besides the power pack.  and what color was the motor for the big trucks. Mine's is blue.How much are the worth. I was just wondering. Thanks for the info
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't know that the power pack heads were an option on a 2-ton truck.
'57 was the first year of the fuel injected 283 horse 283 and there was a dual four-barrel option for cars. But again I doubt very much any of this left the factory bolted to a 2-ton truck. Riding on one maybe...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | The stamp on by the door suggests power pack maybe? but i think it just shows the horsepower with the power pack. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The engine should be green, IIRC. The Power Pak was a Passneger option, not offered on trucks. However, the Taskmaster 283 did use the same 4bbl Rochester 4G carb as the Power Pak cars did, only with a manual choke. But that's about as close as it gets, cams and heads are different. The only Power Pack reference (note the different spelling) I've ver seen inreference to trucks is the Napco conversion, which was also referred to as the Mountain Goat in the AD trucks.
Bill Burmeister | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | OK what year models came with a blue motor? I don't think mine is original then? have a hard time seeing the #on the block. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | cars of that era had blue 235s, no V8's were blue .... after 52 years who can say why yours is blue? would be unusual if the engine hadn't been out for major work some time - numbers are the only way to ID the year of it and if it's "original"
Bill | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Sometimes certain engine rebuilders would paint their engines a certain color as a trademark. I've seen green, black, red and yellow smallblocks over the years. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The smog engines of the 70's and up where blue, Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sometimes certain engine rebuilders would paint their engines a certain color as a trademark. I've seen green, black, red and yellow smallblocks over the years. Jasper used to use a green color on theirs, lately it's been a medium gray. I do know that GM used a nasty greenish yellow on the '57 Passenger use 265s.
Bill Burmeister | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | Whats the price of a good running 283? thanks | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Puryear, The easyest way to tell if you have a 1957 283 is to look for the "side" motor mount bolt bosses (the 3 raised nubs on both sides of the block that the motor mount bolts to). 1957 is the only year 283 that does not have them, they still used the front mount. ALL SBC's from 1958 and up have side mounts. As for value, if it's a true truck motor it's worth about what any running SBC is worth. If by some chance it's a car engine the value could go up. The stamped number on the passenger side tab in front of the head will tell the tail. Mike B  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I think he is looking for an actual number. I would say a complete 283 that needs rebuild a good price would be $300. No more. I know a guy not far from me that has one for sale.... he is asking $300 but hasn't sold it in the past 6 months although I will admit he is not advertising it....just word of mouth. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | That could be a hard question to answer. 283's are still all over the place and rebuildables can be had for $10 to $600. A running 283 could be from $10 to $1500. I've spent $600 for a numbers correct block before. Power pack head are out there and you will spend more on them than they are worth unless numbers matching is your game. How specific do you want to be with correctness when you place it in your truck? If numbers are not important, I would find a 350 (cheaper and easier to find and rebuild) and dress it up to look like it belongs there. Here is a couple of blocks. http://losangeles.craigslist.org/lac/pts/1503740963.htmlhttp://inlandempire.craigslist.org/pts/1498230929.htmlhttp://joplin.craigslist.org/pts/1492962928.html | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | Ok I checked the side of the block and it does have the 3 holes so not original. I got a free 283 recently from a friend and he said the motor had been rebuilt. But it did have some rust in the cylinders but I manage to get it out(sat out side for ruffly 15 years but it was all sealed). so hopefully I will have it running this winter. Its time to replace my worn out 283 with something a little fresher. Thanks for the info!!! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | For the power pak heads look on the front of the head for a triangle, that id's them as power pak 194 intake.Double hump/camel hump id's them as 202 intake.Price of a good 283 is what ever someone will pay,most go for the larger CID.327,350. | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | Power pack heads did not have 194 intakes the intakes where 172. power packs where found on 283 and 250 hp 327 engines. 300 hp 327 had 194 intakes. 375 hp and fuelie 327 had 202 camel hump heads. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Guess I'd better read up on my manuals, My bad. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something else to keep in mind, not all camel hump heads are 2.02 valves. There are camel hump heads out there with 1.94 valves. It's a case of using the same casting for a different application.
