2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
Is there a list of adjusments needed on the Quadrajet carburators? I am rebuilding one on my 70' 3/4 ton GMC
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
Should be included with the overhaul kit,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Ok I was hoping it would be. Since I have this thread going I was also wondering about the front wheel bearings. I repacked my bearings on the 70' GMC two wheel drive. I set the bearings just by feel. I put a little pre-load on them. Is this correct procedure for that or is there a set end play needed?
On the Quadrajet, you might find the rebuild procedure in the shop manual. Try the old car manual project. These carbs were used a lot so you may not be limited to your truck.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Most times you want to turn the nut to where it is snug and all looseness is gone.
Now that don't mean put a big wrench on it and crank till it's tight, but just to the point where it's snug. Then back off that castle nut to where you can insert the cotter pin.
I usually use a small channel lock, that way I can feel the amount of torque I'm putting to it.
If you want to acquire the feel for it, tighten it, back it off,tighten it, back it off, and you will feel the the point at which it gets snug.
A tad on the loose side is better than to tight.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
last weekend on Stacey Davids Gears he ran the nut down on the bearings pretty darn tight an then backed it off 1/4 turn or to where he could locate the hole for cotter pin an gave the rotor a spin an to me it sure looked "WAY" too tight!...but I wasnt there to feel it, I have followed "glasman" Dan's way all my yrs. an it works for me.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Make sure you really blow out all the passage ways on the Q-jet. They run really great as long as they are clean. Use spray cleaner with some type of straw on the nozzel to really get all the dirt out.
Set the idle screws about 2 turns out,
make sure the metering rods are in the main jets on primary side,
and make sure the secondary rods drop in the right location.
There is a lot of moving parts, so double check your work as you go.
Joe
http://www.tocmp.com/manuals/Carbs/Rochester/QJet/index.htm
I found this on the Rochester q-jet maybe it will help. You will have to thumb through it because there are several pages. Good luck. Hopefully you are smarter than I because it looks like a lot of words.
Thank you all for the input. I will check my bearings again as I think I put them on to tight from what you say.
