10 members (WICruiser, Leo, Dennys28, Wayne67vert, Hotrod Lincoln, 46 Texaco, Still At It, GRNHydra, Ponchogl, VicZ),
131
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 50 | Is there a list of adjusments needed on the Quadrajet carburators? I am rebuilding one on my 70' 3/4 ton GMC
1949 Chevy 4400 GrainbedIn the Stovebolt GalleryPhotobucket picturesThe taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back! Behind every successful rancher is a wife who works in town.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Should be included with the overhaul kit, Scott | | | | | Joined: Jul 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 50 | Ok I was hoping it would be. Since I have this thread going I was also wondering about the front wheel bearings. I repacked my bearings on the 70' GMC two wheel drive. I set the bearings just by feel. I put a little pre-load on them. Is this correct procedure for that or is there a set end play needed? 1949 Chevy 4400 GrainbedIn the Stovebolt GalleryPhotobucket picturesThe taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back! Behind every successful rancher is a wife who works in town.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | On the Quadrajet, you might find the rebuild procedure in the shop manual. Try the old car manual project. These carbs were used a lot so you may not be limited to your truck.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Most times you want to turn the nut to where it is snug and all looseness is gone. Now that don't mean put a big wrench on it and crank till it's tight, but just to the point where it's snug. Then back off that castle nut to where you can insert the cotter pin. I usually use a small channel lock, that way I can feel the amount of torque I'm putting to it. If you want to acquire the feel for it, tighten it, back it off,tighten it, back it off, and you will feel the the point at which it gets snug. A tad on the loose side is better than to tight.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | last weekend on Stacey Davids Gears he ran the nut down on the bearings pretty darn tight an then backed it off 1/4 turn or to where he could locate the hole for cotter pin an gave the rotor a spin an to me it sure looked "WAY" too tight!...but I wasnt there to feel it, I have followed "glasman" Dan's way all my yrs. an it works for me. Tim | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | Make sure you really blow out all the passage ways on the Q-jet. They run really great as long as they are clean. Use spray cleaner with some type of straw on the nozzel to really get all the dirt out.
Set the idle screws about 2 turns out, make sure the metering rods are in the main jets on primary side, and make sure the secondary rods drop in the right location.
There is a lot of moving parts, so double check your work as you go.
Joe | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | http://www.tocmp.com/manuals/Carbs/Rochester/QJet/index.htmI found this on the Rochester q-jet maybe it will help. You will have to thumb through it because there are several pages. Good luck. Hopefully you are smarter than I because it looks like a lot of words. | | | | | Joined: Jul 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 50 | Thank you all for the input. I will check my bearings again as I think I put them on to tight from what you say.
