6 members (1955 1 Series, Hotrod Lincoln, Eisenholtz, Otto Skorzeny, Hugh63c10, TUTS 59), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#551793 07/02/2009 2:55 AM
My new van...52 1/2 ton...235...3.55 rear
The motor is very strong...
I'm only getting 10 mpg on the highway at 55 to 65.
I'm going to rebuild the carb.
I'm also going to do a compression test.
What do you guys get?
thekid1950 #551819 07/02/2009 3:42 AM
Don't know, my speedo/odometer is inop,LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #551834 07/02/2009 4:01 AM
I average around 14, if I keep the ol' size 14 out of it.
Bill Burmeister
LONGBOX55 #551866 07/02/2009 4:56 AM
I get 13 MPG around town (40 MPH or less) with my 261, SM420 tranny and 4.10 rear end. The odometer has been calibrated. I'm happy with that.
Wally / Montana #551888 07/02/2009 6:18 AM
Id guess 14 on average in my '53 with the original 216 and 3.55 gears.
My 1953 Chevrolet
1947.1 Gallery
rustednuts #551900 07/02/2009 6:40 AM
I don't drive any of my jalopies enough to figure gas mileage. However when my father used GMCs as work trucks, we figured 15 miles per gallon. This was with 4.57 rears and 7.50x17 tires. They came with 228's but my father would buy 248 short blocks rather than overhaul the 228's and there was a noticeable change in fuel economy with 20 more cubes. We were gasoline distributors and gas was only 20 cents a gallon, but that 20 cents would buy a hamburger.
crenwelge #552031 07/02/2009 7:05 PM
In my '55 1st Suburban, with a GMC 270, SM420 and 3.08 gears in the rear, got almost 18 on a recent highway trip running 60 and 70 mph.
Tires are 235/70-15s and it cruises nicely at 70. I was surprised to do that well, I expected more like 16.
OldSub #552095 07/02/2009 9:57 PM
The last couple weeks I've driven my '50 Chev 500+ miles and averaged 20 mpg. Its a 216 w/3 speed and 4:11 rear end gears. I realize that a car will slide thru the air some better than a truck but still a close comparison.
don stocker #552112 07/02/2009 11:00 PM
10 MPG at 55 MPh. You should be getting at least 20 MPG with that set up.Have that carb checked out. I am running a built 350 with a 700R4 tranny and 3:90 rearend.And getting 20 MPG all day long,city and highway driving.At 10 MPG you gotta be running a way too rich.
dale937 #552141 07/03/2009 12:38 AM
I don't think its reasonable to expect a stock 235 with original running gear to compare to what can be done with EFI and an OD tranny. Better than 10 yes, 20? That's a little optimistic.
OldSub #552150 07/03/2009 12:53 AM
Don Stocker stated..The last couple weeks I've driven my '50 Chev 500+ miles and averaged 20 mpg. Its a 216 w/3 speed and 4:11 rear end gears. I realize that a car will slide thru the air some better than a truck but still a close comparison.
with 4:11 GEARING, that is really something but if you say it is true............then..
Redryder pix
My Hotrod
joker #552163 07/03/2009 1:17 AM
I once got 18 mpg on the trip to the ATHS National Show in Baltimore a few years ago on a 55 mph trip with a stock 235 and stock 3.90 rear end.
20 mpg with a 4.11 rear end and a 216 sounds rear nice.
I am now getting about 15 mpg with a dual-carb, dual-exhaust 261 and a 3.55 rear end. This was on a 230 mile trip from Macungie PA at 60-65 mph with a calibrated speedometer and a very heavy passing-foot.
OldSub #552167 07/03/2009 1:20 AM
I get about 19 out of my 350.
11 on the highway and 8 in town, that's 19...
Avette4me #552206 07/03/2009 2:39 AM
I could drive my 52 to work for 2 months on a tank of gas..
Redryder pix
My Hotrod
joker #552214 07/03/2009 2:58 AM
Last edited by Avette4me; 07/03/2009 11:45 PM. Reason: spoke like an adult, don't like being policed
Avette4me #552222 07/03/2009 3:21 AM
Joker I wasn't doubting Don's word, but responding to the later post saying thekid1950 should be getting 20 with his pickup.
It might be possible to get 20 mpg out of one of these old pickups with a stock motor and drivetrain, but I don't believe its realistic to expect it as a daily experience.
Change the rear gears and/or add a overdrive, and update both the ignition and the carb and I bet its still tough to do.
joker #552227 07/03/2009 3:29 AM
I get 16-mpg in my One Ton. In town, around town, and loaded or empty. I'm in fourth my 20 mph, 15 mph unloaded, as my truck has the 5.14. I would imagine that on the highway going a steady 45-mph, I would do better. But, that never happens, and I accelerate slowly, though all 4, every time. The truck runs 35 miles a day, so it gets to warm right up. Its as good as any real truck I've ever driven in town.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #552415 07/03/2009 9:57 PM
I was amazed by the numbers myself. I averaged it out over 4 days going back and forth to St Paul MN for a car show. Mostly 2 lane driving, 45-50 mph and just taken it easy enjoying the ride. I also have a '47 F**d tudor that was along for the trips and it averaged 11. Its got a stock flathead and tuned properly. Bottom line in my book is the 216 is all its cracked up to being and then some.
Don
OldSub #552530 07/04/2009 5:24 AM
Why worry??
dg
dale937 #552782 07/05/2009 1:30 PM
And Dale, you should have your speedo checked. I know I only get 15, and proud of it, on my 350 with about the same gearing.
gazim #552795 07/05/2009 2:35 PM
Oldsub,,, your statement..joker I wasn't doubting Don's word, but responding to the later post saying thekid1950 should be getting 20 with his pickup.
I never meant to say you were, maybe it was me...lol
you gotta make sure your tank is full when you figure the mileage and full when you feel it up at the end..20 miles to a gal in any old truck is a lot...........regardless of gearing..
but it is his story so I am sure he is sticking to it..lol
my rod will get a good 20 on the hi-way driving at 70 plus, but it also has 2:73 gears..
Redryder pix
My Hotrod
gazim #552804 07/05/2009 2:52 PM
I would expect about 15, my 250 sets about that. Its hard to compare a V8 to a six due to the torque curves and low rpm horsepower. It takes a lot of tuning to get a carburetor to work at very low rpm (overdrive)and still pull the truck.
Joe
thekid1950 #552846 07/05/2009 5:58 PM
Originally Posted by thekid1950
My new van...I'm only getting 10 mpg on the highway at 55 to 65.
This one has been flogged hard. Let us know what a van is, willya?
10 miles is not far, but for a step van with the wrong gearing, it could be...
1951 3800
-hotshoe
OldSub #552951 07/06/2009 1:19 AM
i get 12 with a 235 with dual carbs and 15" tires and 2.73 rear end this around town. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
hotshoe36 #553007 07/06/2009 4:39 AM
Its a 1/2 ton Chevy Suburban
I also have a 51 Chevy 3/4 ton
235, 4 barrel, duals, 3.4 rear, T5...
I get 16.5 over last 10,000 miles
thekid1950 #553150 07/06/2009 6:57 PM
Oh. Heavier than a pickup, but I'd still want more than 15 mpg on a straight, flat highway at a legal, steady cruise. Especially with that 3.55 ratio.
First the compression test, then an ignition tune-up. After that look at the carb. That would be my plan.
Of course, an inspection of tire condition and pressure would precede any of that. What rubber are you running, by the way? OE 16" tires would be a definite negative in looking for economy.
1951 3800
-hotshoe
hotshoe36 #553406 07/07/2009 2:56 PM
I'm getting 14 MPG with a '53 235 and 3.90 gears
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #554630 07/11/2009 12:26 PM
Y
Y Offline
I get about 18 in my 49 3600 when I keep it below 50 with the stock rear axle, 4 speed and 216. same with my 3100 up to about 55 with the stock 3 speed, 216, and rear end. It sounds like a carb issue or to much lead in the accelerator issue. grin
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Yelostn78 #554634 07/11/2009 12:58 PM
i have dual carbs on my 235 and 2.73 rearend and when one of the carbs was inoperative i got 19. i was not aware that it wasn't working. as i said above usually around 12. will check again soon, just got it back from the shop. ron
2017 Buick Encore
See more pix
