7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible),
227
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Most steering upgrades to power steering for the 1947-1955 1st series calls for a '68-up till about '86 GM Saginaw steering box... with all the power steering kits I see from American Classis and Classic Performance Parts. (I like CCP' write up on the conversion. Very well done.
I've been checking the #'s at Advance to see what one would cost and found that 1968-1976 use the same part #........$152 plus $75 core 1977-1979 use same but diff part#... $139 plus $50 core 1980-1986 use same but diff part#... $152 plus $125 core
I looked all these up for a 1/2ton C-10 half ton pickup. (well I think one of the '80's was a G-10)
All that to ask one simple question. WHATS THE DIFFERENCE?
I couldn't view all of them at one time but they all looked the same to me as I looked them up individually.
If they all have the same bolt pattern and will work then what year would you choose? The latest year??....what ever the difference it must be what changes the core charge.
OOOOOK, lets here from the guys who know! I'm waiting on answer before buying a steering box.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here's all I know. I put a mid 70's C20 (3/4 ton) box in my 64 C10 and the steering ratio was almost too tight. It would react to any little movement of the steering wheel. The truck I got it from had the large split rim wheels on it so it must of had the closer ratio than the smaller trucks. Once I got used to it, I liked it, Scott | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I thought the same thing dinking around with some that I had laying around. Turns out a 1/2" difference looks the same until you measure them...
So I guess I dont know!
Jeff | | | | | Joined: Feb 2004 Posts: 29,783 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,783 | Scott, some of those Saginaw power steering boxes have a tall tooth on the center of the worm gear. It makes for a very quick response just off the center point, and the ratio slows down as you approach the end of the helix. I think the variable-rate design originally came out on Cadillacs, and pretty soon it was adopted all across the GM carlines. Not too sure about when they started putting them on trucks. It made for very quick lane changes while still allowing a good mechanical advantage for parking maneuvers. Jerry
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | http://www.rockauto.com/catalog/raframecatalog.phpI'm not sure what the differences are but I used one for a 69 C10 and it works fine. I know they have a close ratio one too. I believe 77 and up have metric hose fittings, which means your power steering pump would have to match. I bought mine from the above link. It's $124.99 plus $75. core charge for one from A1Cardone, which is the one I used. I bought parts from different part sources but in hindsight I would have been better off buying a complete kit. I think it cost me more doing it this way, but I'm very pleased with the outcome. Brothers sells the complete kit too. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 1980 up had different fittings for the hose connections. They went to an o-ring type. Some where they had a different dia. shaft that connects to the column but you can use the corresponding rag joint. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks guys. I think I'm gonna shoot for somewhere around 70-72 and I'm gonna use the 68 steering column a friend gave me. My nephew has a core I can use and I get hoses/sectors ect at Advance with my discount. I'll get one of those conversion kits that has the drag link,bracket ect from one of the vendors...... Right after I get some of the "small stuff" back on the panel and out of the way!
EDIT: correct the year of steering column I"m using
