1 members (NJC),
77
Mod | | | Forums66 Topics128,283 Posts1,058,506 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Chris: Great work, shows a incredible attention to detail in every aspect of your truck. Hang around and answer some questions from us beginners.
~Jim
| | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | I mounted new shocks all 4 corners,took off a piece of iron that had been welded between the frame at rear,was'nt able to put brackets on because of it.Hope to mount bumper tonight.Took my rim out to a shop to have it straightened out,i pick it up today.Will be having a discussion with the shop that told me the wobble was my axle.Made myself a list last year,startimg to whittle it down,one step at a time.  | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | Pictures of the rear fenders installed I got the rear fender painted Friday and installed them Saturday. I couldn't get anybody to do the fenders for me so It was my first attempt at body fill and painting centari. The truck now has three different people painting different parts and 2 shades of blue. the cab was done when I got the truck and I could never figure out what colour it was. All I have left to do now is the two front fenders and they are rough. The drivers side is very solid but full of dents. The other fender id straight but full of holes.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Looks good. I'll be taking on body work for the first time this year also.
Bruce | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I think I applied 3 qts of fill and sanded off 2-1/2 qts. also almost 2 quarts of high build primer and a ton of sand paper. I building the old truck as a driver so I not fretting on anything being perfect. I also started this one with the idea of doing everything as cheap as possible. I did have all the box blasted to bare metal and expoxy primed everything. I think it will be a fun old truck when done. I had the front fender over to a friends place and we had it on the english wheel last night and got out some of the dents | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I finally got a roof over my truck. I am having to reuse some metal off of my rental house as I replace the roof on it. I cut the cedar post and braces out of logs with a chain saw. I am a happy camper we have gotten almost 8 1/4" of rain in the last two weeks and it feels good to know that at least the truck will be dry. The shop | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Everything looks good!! I like the shop.
Iron Clad | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | General Truck Talk is for talking about our old trucks. Please post only what you did to your truck. I have deleted several posts about what people didn't do and about doing non related stuff.
Thanks. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Finally figured out why my door poppers weren't working. I had to tweak the wires going to the relay. Now when the doors open the courtesy lights light up, that is if the doors were on. I also bought a "Lokar" throttle cable and a "GotaShow" power steering hoses. I'll probably bolt them in this weekend.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I got some more cleaning and painting done(Cowl panel and speaker grill),shortened my alternator bracket,modified(?) my air cleaner and sorted out my booster vacuum hose. Got my new top shock mounts from Air-ride and mocked them up and still had time to visit our friend who's home from Va. All in all a reasonably productive weekend!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Finally figured out why my door poppers weren't working. I had to tweak the wires going to the relay. Now when the doors open the courtesy lights light up, that is if the doors were on. I also bought a "Lokar" throttle cable and a "GotaShow" power steering hoses. I'll probably bolt them in this weekend. After seeing how little room there is around the P.S. pump and steering rack I believe I'll just wait until I finish mock-up on front sheetmetal and have it off to the painter's before I hook that up. The gas pedal will need to wait until I figure out how to mount it to the firewall.
~Jim
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I put my NOS fan pully and a fan spacer on, put a belt & the fan on, added some antifreeze and went for a ride. First of the year. too.
Found out the fan spacer is needed to keep the fan from hitting the pullies in front of the harmonic balancer.
After being parked in October it started right up and ran fine, but I had to add some air to the tires.
I love it.
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I've been in the trenches filling and sanding my '55. The stage I've wanted to be at for a long time. I enjoy bodywork..Did all the patch panels 2 years ago and now it's filling, sanding and alaigning panels. This week It's the back of the cab which looked like the bottom of an egg carton. I'll add a pic to photobucket tomorrow.
BTW Eric I went to your webshots and was pleasantly surprised. I've decided to paint my truck Omaha Orange. Just this week I decided to paint the rear window area white and * ain't there one like that at your webpage. I even started a thread Sunday I believe about the two tone concept. Is that your truck? Wonder if the white is Bombay Ivory...or is it Bombay White..
Nice truck ..whoever owns it.
Keith
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Primered, wet sanded, primered, wet sanded, primered, wet sanded. You get the idea. Waiting on some consistently warm weather and the rains to stop and then plan on spraying some color. Got the bed boards sealed and sanded. Then I get to start wet sanding. | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | I spent the weekend separating the e-brake rod from it's spacers and the frame. Over the years of storage, diesel fuel leaked down across those parts and fuzed them together. I finally got everything separated, now I can replace the e-brake system and repair the frame. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I built enough storage in the shop to clean all of the tools and parts out of my cab. I test fit the drivers side floor and it looks good so far. Now I can get to the interior to work without removing all of the crap and putting it all back in when I am through. It sure is nice not to be working outside. It is real nice not to have things rusting back up as quick as I clean them. shop I still have to build some doors and cut enough cedar for the siding. I am going to leave the post exposed and have some 4'x 8' sheets of 4" styrofoam to go under the siding for insulation. It should be like working in a big ice chest. Life is just good. | | | | | Joined: Feb 2009 Posts: 22 Apprentice | | Apprentice Joined: Feb 2009 Posts: 22 | Bought a 51 3/4 t GMC a few weeks ago. Got the brakes working a little bit, still need bled out. Engine was running, but had a backfire when starting and ran poorly. Found the 4 and 5 plug wires were crossed up and now it purrs like a kitten, Drove about 2 miles and had a ball. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Washed the truck and started waxing it. I've got a car show on May 3, first of the season, and it's also my longest drive ever in the truck - 85 miles each way. Wish me luck. | | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | went to a car show and pulled the motor and trans out of my 1946 chevy pick-up the yellow for a rebuild.thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I drove the '56 about 250 miles. Saturday morning we drove to several historic sites in Palo Pinto County. Then Saturday evening I drove to Fort Worth for the Sonic cruise-in. Met Cliff59 and TXLATX there. Man, I love driving that truck. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I finally got back to work on the cab this weekend. I replaced part of the seat pan and plugged up the gas filler hole. The one mandate from my wife was that the gas tank be moved. There are 5 or 6 photos after the link. http://rides.webshots.com/photo/2212574500103315458JMYeKt I really hated to cork up the filler hole but what is done is done. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had the same feeling as I plugged the filler hole, but I wanted the gas tank out of the cab. As far as this weekend I did nothing but sit on my bohiney and watched the rain. We must of had 5 inches in 3 days.
~Jim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hung the doors ,got them back from painter , cleaned the steering colum and box to get ready to paint , worked on the drivers door some more because I just can not leave it alone was good but just had to play with it took it off , bend hinge now I got to put it back on it all looked good when I test fit before paint , I did somthing wrong a glitch a senior moment what ever , as long as I can fix it I can move on .
Pete | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Oh boy, you guys get lots done. I made up new lines to tie the tarp on the truck, even whipped the ends. I replaced my drivers door latch, now my dang door doesn't open when I turn right, and go over a bump. Who knew having doors that stay shut is such a luxury, its sooooo nice though! I also washed my floor mat, it sure looks nice now! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | 9/14/09 got all the one-ton bed parts wire brushed and treated with rust etcher. removed six layers of paint from the bed aprons and pinged out the dents. | | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | On Saturday I finished building my 350. All I need now is money to get the intake manifold, then I'll be good to go. Also started contemplating cutting my long bed to a short, but on Sunday saw a truck for sale with a long bed, which I might need to go and take a look at...
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I love this thread it is nice to see what people are doing. Love the mater truck. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | caroline & I put the first 30miles on Lucinda. we just tagged her thursday and saturday we made it to the local 800+ car show http://www.roaminangels.com/htmls/carshow.html w/ the vincent [ http://www.thevincent.com/vinmodel.htm & www.thevincent.com/ ] in the bed I did a two-fer
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Didn't get as much done as I would like,but a little and often,gets it done.(eventually) I'm still working on the steering/gearshiftStill, I'm a little closer to the big day!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jock: How did you polish the steering shaft et.al.?
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Big....Look in the background at the bench in this picture and you'll see a bench grinder with a polishing mop. It was pretty easy actually,the CNC finish from Borgeson is so good,it polishes up real nice!(They're Stainless which helps) I started with a sisal mop and then onto the bound cotton,in all about 1 hrs work. P.S. Goggles and gloves are mandatory,these things get pretty dang hot!
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | All of you put me to shame. I did start assembling my 216, but it's slow. Better to be careful than careless. Regarding Lyndsay's garage pics: I just wish I had a classy Post & Beam garage like that.
Drew
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just got in from installing the front discs on my new Suburban. Hope to get the power master cylinder in tomorrow. | | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | I fabricated a stainless bellcrank for the throttle linkage on the 261 installation. It didn't work so well so I remeasured and made another template. MEASURE TWICE AND CUT ONCE! The second one works great. Took the truck out for a test drive and all is well. I'm finally finished. Well, almost. There is the issue of repainting the dash and finish detailing the interior, but the engine project is done. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I just got in from installing the front discs on my new Suburban. Hope to get the power master cylinder in tomorrow. Let's see Cletis, a "new" suburban needs discs and M.C.?
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Here are a couple shots of the Fried Green Tmater with the one-ton bed installed. Ordered new running board to bed aprons, taillights with brackets and bed mounting kit from Jim Carter. It is mounted "dry" now with some spare rubber body mounts I had laying around. Once everything is perfect I will take it all back off and paint the pieces individually. drivers side passenger side | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That looks nice. Gotta love those 1-tons. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I sure do like those long beds.
~Jim
