7 members (Greg_H, Joe H, Tinker5, Ridgeback, WICruiser, 2-Ton, Bill Hanlon),
132
Mod | | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | How many of you have V8's in your trucks (older ones)?
Specs, love it? pics? | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: May 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 24 | getting ready to put mine in | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have a 350 Goodwrench engine in my '56. Running an Edelbrock 650 on it with stock type exhaust manifolds. TH400 tranny. Spicer 3.07:1 rearend from a '59 GMC. Pics on my website. No engine pics though. Is that what you want to see? | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Thanks cletis and others, I thought I was the only oddball | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I also have a V8 in my 62 pickup I also have the 261 that came out of it. It's a 350 punched out to 355 with Keith Black Pistons, Comp Cam, Proform Roller Rockers 1.5 to 1 21/2" GM. Rams Horn Manifolds, Street Damper, True Roller Timing chain, Preformer Intake, 600 CFM Carb, Aluminum Water Pump all by Edelbrock, GM Fuel Pump, Lokar Shifter and the engine Balanced with a GM 400 Tranny to a 373 ratio 12 Bolt GM Limited Slip Rearend. This truck is going to be a daily driver and to pull my fishing boat. It will have approx. 300HP. I consider this a non hotrod truck. Now you all know when you get started on a project like this it has to be laid out before hand. The other stuff I have done to the engine to make it run better and make it last was to send the exhaust manifolds in to have them powder coated with high heat retention coating which makes the exhaust run cooler in the engine compartment. Griffen Aluminum with Spal Fan for cooling and B&M Trans Cooler for the trans cooling I have spent $7000.00 on the truck chassie and other equipment like AC etc. so far and $2500.00 on the rebuild and parts for it. The engine will resemble a 1960 engine rebuild. So that is that so far and hope to be able to post my pics of the truck in progress soon. I hope you guys do not think I am braging about what I have done as I just like to tell people what can be accomplished on a tight budget. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | My '59 half ton has a 350 with a turbo 400, all of the others are 6 bangers.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Have a bored and balanced 327 in mine - roller rockers, cam, intake, headers. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a Chevy 350 in one and a Cadillac 500 mocked up in another. If I can include the ones too new for Stovebolting I have another 350 and two 454's.
I also have another Cadillac 500 currently surrounded by a Cadillac, but I think its going to find its way into a truck someday too.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Mine has an '81 Corvette motor(smog monster)a TH350C Trans with an '86 Firebird rear end with 3:27 posi diff. All stock (I think)..... for the moment! I haven't been inside the motor.
Check out my Flickr page. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | My '54 Chevy Panel truck has 350 4 bolt main out of a '77 Suburban 4wd. Stock Quadrajet and stock exhaust manifolds. TH350 tranny. '76 Monte Carlo rear with 3.08 gears. Front suspension is '73 Nova with disc brakes. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | 350 /350 turbo set up in my 52 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Mine all have 350 v-8,s. The first thing I do when I get a truck is order a new Goodwrench engine for it. Then I go from there. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Is that a 327 with a TPI? I thought TPI's fit only 350's | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | '62 stepside. 350 punched to 383, '89 IROC fuel injection, roller cam and rockers, edelbrock heads, headers, 4 speed. | | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | I feel like V8's are pretty commonplace. The oddity is a V8 with a stock frontend. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Is that a 327 with a TPI? I thought TPI's fit only 350's Yes it is. TPI will bolt up to 283, 327, 305, 350, just about any SBC.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | V8? Is there anything better ? I've got a built 327/350hp with an M21 & 12 bolt.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Big Block Olds for the '48
| | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | I have a 327 out of a 66 caprice in mine. Believe me I kind of wish I had the original 235 | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | 454 BB TH400 in my 47 2ton still have to figure out the exhaust manifolds. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Bad A$$, love the old school tunnel ram. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | 454 BB TH400 in my 47 2ton still have to figure out the exhaust manifolds. Could remove the fenderwells and go with fenderwell headers. I have a catalog with all kinds of dimensions for different types of headers. | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 |  OLD SKOOL RULZ many people shy away from such set-ups, saying they use too much gas, hard to tune etc. But ya just can't beat the look of a tunnel ram! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Have a 350 with a 700R4 in my 37 pickup and have a nice 305 re-man engine sitting in the 52 Panel chassis and a 350 turbo for this one unless I can find something else before its to late!! | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | I feel like V8's are pretty commonplace. The oddity is a V8 with a stock frontend. My '59 half ton still has the straight axle underneath the 350 V8. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | 1955 2n/d series 350 GM and 700R4 trans. 1965 has a 500 cu in Caddy and turbo 400 trans. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | 1955 2n/d series 350 GM and 700R4 trans. 1965 has a 500 cu in Caddy and turbo 400 trans. | | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | Tunnel Rams are cool, but I'd like to see a truck with a Smokey Ram in it. That would probably square up to the inner fenders nicely and fill the engine bay up something sweet. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I have a ZZ4 350 crate engine with Street and Smiths Headers and a Demon carb, backed up with a 700R4 tranny. Runs real good!! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | '78 350 from a Z28 in the '47 in progress. Yes it is Camero subframed too.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 283/TH350 in my 49 sub.
Weeds | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | stovebolts aren't v8s. i would like to have a straight 6 atlas in mine if anything happens to my original 6. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | I'm shopping for a 3.8 liter dual overhead cam Jag engine (I-6) to build into a stovebolt. The sports car racing team I hung out with back in college had a 55 1st. series short bed for a pit truck with a Ferarri V-12 in it. That one got everybody's attention, especially since it had the original straight front axle and drum brakes all around! The rear axle was out of a Jag XK-140, and the trans was a Colotti 5-speed. Jerry
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Very true on the stovebolt description. Once you go to V/8 power it is no longer or probably never was a stovebolt. The term stovebolt was used for the old Chevy sixes,many years ago.Probably the 1929 version.Which at the time surpassed Ford in horsepower as Ford was still using the straight 4 cyl engines of that era.Of course in 1932 Old Henry put it to Chevy with the new flathead V/8. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | 350 4 bolt, .30 over,speed pro hypereutectic pistons,eldebrock performer intake,cam and carb..................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | stovebolts aren't v8s. i would like to have a straight 6 atlas in mine if anything happens to my original 6. ron I am 100% with you on that Ron. My '59 was already in a "butchered" state when I bought it. I just want to get it running and back on the road. The Atlas 6 would be cool, real cool. John
