7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible),
109
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | Has any of you bolter's out there in truck land put a late model 6 in an ole 53? This may sound dumb but, I was wondering about any input about front motor mounts. I bought a bell housing from a 63 1/2 ton with v/8, so far so good, but it looks like I might have to modify my crossmember for it to bolt up...........any suggestions would help-----------resto | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think you'll have to buy a V-8 conversion cross member to bolt a 250 in. They have the mount on the side like the small-blocks do. Scott | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | the guy i bought my fifty from put a later model 250 in it. he bolted the orginal 4 speed tranny right up to it and to this day i still dont have/need a crossmember for my tranny.
he fabricated the motor mounts himself, let me know if you want a pic of how they look.
i honestly would never do this change, its too complicated and alot of modification. just throw in a 235 or 261. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Resto 44, although I didn't do it, my 52 has a 250-6 in it. I like it. It's hooked up through the stock tranny/rear-end, and with the HEI ignition, runs great. With that motor, and the remainder of the stock set-up, I cruise right at 60 mph real comfortably. As others here have said, the motor mounts have to be changed to the side, and new ones either created, or purchased and put in place. However, there have been no modifications to my crossmember. Engine is also longer, so you'll probably have to move your radiator forward etc. Good Luck. | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Resto, look in the links section for Chuckthetruck. He has a really nice website showing his truck rebuild. I am sure that he put a 250 in his. | | | | | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | I put a 292 into a 54 6100 which has the side motor mounts the same as the 250 but slightly different positions. I cut the brackets that are attached to the frame out of the 1970 donor truck and cut them down to fit the narrow frame of the 54. I bolted the engine to the transmission and held it in place with the engine hoist and cut the brackets to fit and then bolted them in place. I haul 9000 lbs of water almost every day with ou any problems. Jim | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Are the later 63-... straight six side motor mounts the same as small block mounts? | | |
