Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (DennisM, Petrolhead 69), 107 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
#3911 03/30/2005 3:09 AM
Has any of you bolter's out there in truck land put a late model 6 in an ole 53? This may sound dumb but, I was wondering about any input about front motor mounts. I bought a bell housing from a 63 1/2 ton with v/8, so far so good, but it looks like I might have to modify my crossmember for it to bolt up...........any suggestions would help-----------resto
#3912 03/30/2005 5:12 AM
I think you'll have to buy a V-8 conversion cross member to bolt a 250 in. They have the mount on the side like the small-blocks do.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#3913 03/30/2005 6:20 AM
the guy i bought my fifty from put a later model 250 in it. he bolted the orginal 4 speed tranny right up to it and to this day i still dont have/need a crossmember for my tranny.
he fabricated the motor mounts himself, let me know if you want a pic of how they look.
i honestly would never do this change, its too complicated and alot of modification. just throw in a 235 or 261.
#3914 03/30/2005 2:15 PM
Jed Offline
Resto 44, although I didn't do it, my 52 has a 250-6 in it. I like it. It's hooked up through the stock tranny/rear-end, and with the HEI ignition, runs great. With that motor, and the remainder of the stock set-up, I cruise right at 60 mph real comfortably. As others here have said, the motor mounts have to be changed to the side, and new ones either created, or purchased and put in place. However, there have been no modifications to my crossmember. Engine is also longer, so you'll probably have to move your radiator forward etc. Good Luck.
#3915 03/30/2005 4:39 PM
Resto,
look in the links section for Chuckthetruck. He has a really nice website showing his truck rebuild. I am sure that he put a 250 in his.
1951 1 Ton Completed
#3916 03/30/2005 4:50 PM
I put a 292 into a 54 6100 which has the side motor mounts the same as the 250 but slightly different positions. I cut the brackets that are attached to the frame out of the 1970 donor truck and cut them down to fit the narrow frame of the 54. I bolted the engine to the transmission and held it in place with the engine hoist and cut the brackets to fit and then bolted them in place. I haul 9000 lbs of water almost every day with ou any problems. Jim
#3917 03/30/2005 7:47 PM
Anonymous
Unregistered
Anonymous
Unregistered
Are the later 63-... straight six side motor mounts the same as small block mounts?
