10 members (DaveV, Joe H, Oswald, Phak1, GA Boy, 55shaker, Jay R, 32vsnake, Goach2, Ridgeback),
92
Mod | | | Forums66 Topics128,198 Posts1,057,270 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | PO got overspray on the side and rear glass of my 56. What is the best and/or easiest way to remove it? | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Option 1) 000 or 0000 steel wool (w/mineral spirits or Windex) Option 2) Straight razor and Windex Or option 3) HAMMER
| | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | See my reply in General Truck Talk. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Try the razor blade. Use thinner or mineral spirits and be careful not to get it on your new paint! | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | you can always buy new glass 8-) | | | | | Joined: Jun 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 23 | You can use laquer thinner, but be careful.
Making chicken salad out of chicken sh!t. 1955 Ford F100 1954 GMC
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I would think the laquer thinner is best, like you were warned though. It depends on the paint your using and it can take off paint you dont want off either, just be careful. | | | | | Joined: Feb 2008 Posts: 1 New Guy | | New Guy Joined: Feb 2008 Posts: 1 | Back from the dead i know, use a claybar, works WONDERS and wont hurt your paint | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Here is an option you wont here most people suggest. Tooth paste ( the old kind - white ) and a soft cloth. This should get the stuff that the straight razor blade missed.
Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | I own a window cleaning company and get overspray and paint off glass all the time. You don't need any solvents or thinners to worry about your paint. Just squirt some Dawn or Joy into your water, make it fairly sudsy, and put it on your glass. You can use 0000 steel wool, 000 can scratch or a sharp razor blade, either one works. The soapy water keeps the glass from scratching, it works on trucks or houses, just don't scrape any glass dry you will scratch the glass.
Squeegebob
| | | | | Joined: Feb 2008 Posts: 5 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 5 | I have a shop here in pasadena, tx and all those things work,but has it's disadvantages.steel wool brakes down into very littal peaces that will get stuck in your window felts & on you exterior paint,if you do not totally remove it ,the next time it rains or you wash the car ,those peaces will rust leaving spots on the paint. Auto glass is tempered so they will shatter on impact,that makes them softer,so razor blades scratch but you won't notice it until your inside. the best thing I found for cleaning windows that works very well is I mix a med. rubbing compond & a carnuba or butter wax 1/2 & 1/2,this solution is good for cleaning rubbers, moldings,all your aluminom & chrome. It work very well for interior switches, knobs & all those hard to clean spots with years of grim,it cleans and shines at the same time. If you have what looks like acid rain spot on your glass,this solution work good for that,but it dose take some rubbing. I hope this help.
| | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Don't use an old blade with rust on it because it will scratch the glass!
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Ive had plenty of luck using WD40. Spray it on. Wont hurt your paint at all, use a new razor blade to gently clean your window or even some newspaper. | | |
