9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Does anyone know who carries the brass banjo fitting for the front brakes? I checked a few vendors but can't seem to find it. I see the block type line splitters but not the banjo type with the through bolt. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Actually now that I think about it, I don't need the fitting itself, just the bolt and new copper washers. Anyone know where I can find these? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might try the flaps, too. They should have the copper gaskets (washers), possibly the bolt too. Take the old one so that the thread pitch can be verified (should be fine threads).
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My FLAPS has boxes of banjo bolts and copper washers available. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I checked recently and in my area they are scarce as hens teeth. A good stovebolt buddy came to my rescue but I did see them as mentioned above in JimCarters catalog. The FLAPS around here have the compression washers but I would have to buy TWO packs just to get the size I needed. The packs cost as much as we can order the bolt WITH washer from Carters. I forgot to check NAPA which usually has that around here. I'll check it tomorrow!! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | do ya have a local Hydraulic line place ??... Mine has always had everything I ever needed ..My local shop is called Brake Drum & Eqpt... they have or can make any high pressure line you may ever need and there parts (washers ,banjo bolts) there price is usually better than the local FLAPS..an ya get exactly what ya want ! no mixin this an that to MAKE IT WORK. Just my 2 cents Tim P.S. usually you can find a line shop close to a Truck Stop .. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, never gave the hyd place a thought. There is a couple in nearby in my hometown and I believe one of my old school buddies may still run it. I'll give NAPA around here a shot and if no luck I'll check when I go over to see my nephew. I only need 4 or them suckers but refuse to buy two packs just to get them!! Thanks Tim | | |
