3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#363423 01/21/2008 1:13 AM
Does anyone know who carries the brass banjo fitting for the front brakes? I checked a few vendors but can't seem to find it. I see the block type line splitters but not the banjo type with the through bolt.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Actually now that I think about it, I don't need the fitting itself, just the bolt and new copper washers. Anyone know where I can find these?
Mike
You might try the flaps, too. They should have the copper gaskets (washers), possibly the bolt too. Take the old one so that the thread pitch can be verified (should be fine threads).
Bill Burmeister
My FLAPS has boxes of banjo bolts and copper washers available.
My 1953 Chevrolet
1947.1 Gallery
~Jim
I checked recently and in my area they are scarce as hens teeth. A good stovebolt buddy came to my rescue but I did see them as mentioned above in JimCarters catalog. The FLAPS around here have the compression washers but I would have to buy TWO packs just to get the size I needed. The packs cost as much as we can order the bolt WITH washer from Carters.
I forgot to check NAPA which usually has that around here. I'll check it tomorrow!!
do ya have a local Hydraulic line place ??... Mine has always had everything I ever needed ..My local shop is called Brake Drum & Eqpt... they have or can make any high pressure line you may ever need and there parts (washers ,banjo bolts) there price is usually better than the local FLAPS..an ya get exactly what ya want ! no mixin this an that to MAKE IT WORK.
Just my 2 cents
Tim
P.S. usually you can find a line shop close to a Truck Stop ..
1952 Chevy Shortbed
Photos in Photobucket
Tim, never gave the hyd place a thought. There is a couple in nearby in my hometown and I believe one of my old school buddies may still run it. I'll give NAPA around here a shot and if no luck I'll check when I go over to see my nephew. I only need 4 or them suckers but refuse to buy two packs just to get them!!
Thanks Tim
