3 members (J Lucas, HandyAndy, TUTS 59), 39 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#327622 12/04/2006 4:13 AM
Anybody out there have any problems with wind noise from the doors on a 55-59? I have installed new door rubber and the doors are aligned great. Driving around town is not a problem. It's when I hit the highway when it gets loud. It is difficult to listen to the stereo or have a conversation. Anybody have any cures? frown
'58 Apache Short Fleetside on a '64 chassis
#327623 12/04/2006 7:10 AM
If your doors are all sealed up and you know it's not that, then it must be your windows need new felt channels.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#327624 12/04/2006 11:09 PM
go around the door seals with a dollar bill if you can remove the bill easy when shut adj in,,if window noise ,,is felt good if good look at stops also where is crank located when window is closed...doc
#327625 12/04/2006 11:20 PM
Hey, Doc
What do you mean when you say where is crank located when window is closed ... how does the crank position effect anything?
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#327626 12/09/2006 5:30 AM
2 Offline
Your right Alan, the crank postion has nothing to do with anything.
Terry K.
27 Chevy Capitol 1 Ton
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one.
-Ralph Waldo Emerson-
#327627 12/10/2006 2:21 AM
It does if the window tends to fall back down. With the weight of the crank pulling down on the regulator, which rolls the window up, then the window will stay up. If the weight of the crank is the other way (180 degrees), it will allow the window to work it's way down as you drive along. Some windows are too tight or stiff for this to matter but I had a 64 that would roll itself down because of this.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#327628 12/10/2006 3:34 AM
Scott's right. I've seen that happen before.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#327629 12/10/2006 6:22 PM
Thanks for the tips guys. I have new felts in the windows as well as new door rubber. The windows seal up nice and the glass doesn't giggle down on a bumpy road. I can see daylight out the top of both doors. The dollar bill trick won't work there but a catalogue might. I get a good seal on the rest of the door, it's just the top. The doors are aligned nice and close great. Perhaps the door tops need to be bent in a bit.
#327630 12/11/2006 2:47 AM
2 Offline
Scott, Good point, Thanks for the info. Never gave it a thought before. I would have guessed the felt and new door rubber would have been enough to keep the glass up.
Terry K.
Terry K.
#327631 12/11/2006 4:04 AM
sometimes the top part does need "pulled in". I once had to put my knee against the inside panel and pull the top part of the frame in towards the cab. Solved a lot of my wind problems.
#327632 12/13/2006 6:26 PM
I did the dollar bill trick like Doc suggested and I have a great seal around the doors except at the sharp curves at the top of the door above the vent window and also just in front of the vent window. It is only at these sharp curved areas and I can probably manipulate the rubber to close it up. Someone suggested useing pieces of windshield washer hose to shim the weatherstripping. I haven't done it yet but sounds like a solution.
#327633 12/13/2006 9:08 PM
I heard a guy say once that he put a 2x4 in the bottom of the door ... closed the door against it and pushed on the top of the door. It worked for him.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#327634 12/14/2006 7:26 AM
Achipmunk is absolutely correct. I too have done the knee into the center of the inside of the door trick and bent the top inward with everything I had. It is amazing just how much it tightened the gap above the wing window.
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
