6 members (TooMany2count, 78buckshot, Gdads51, KEVINSKI, dt235sd, 1 invisible), 161 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
I'm getting toward the end of my restoration, and I have these matching pieces left over. I suspect they're either for the doors, or somewhere up under the dash. Does anyone recognize them?
http://s242.photobucket.com/albums/ff77/stovebolt48/
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Throw them in the doors panels, the rattles make you feel needed. grin
They're for the center strip for the windshield. They go on the inside.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
I don't think they are for the windshield divider. But then, I am not sure what they are.
I think the hold a weatherstrip on the lower door opening,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Leo Offline
Moderator
Moderator
I think Pablos is right, looks like the windshield strips.
By windshield strips, do you mean the inside center strip? I have that, and it's a lot larger. The holes don't match up to the ones in the rubber or the outside chrome strip, either. And why would there be two of them, anyway?
Also, once again I failed to mention that the truck is a '48 half ton.
Gazim might have the right idea, but I'm sure I'll have plenty of stuff rattling around without these strips banging around in the bottom of the door. grin
1948 Chevy 1/2-Ton
Tom R:
Be a helper (usta work with pre-schoolers) and load up a bunch of pictures as you put that 48 together.
Many of us will be doing the same before long and those images will help us put the puzzle together.
~Jim
Junior Member
Junior Member
Those are the rear headliner support strips.
They mount between the middle & rear headliner bows & they keep the headliner from drooping.
I agree w/ truck master
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
Headliner supports makes sense. I haven't put them in yet. Where, exactly, do they go, and how do they attach to the headliner?
As for pictures, I have a ton of them from over the past three years. I'll try to post them to PhotoBucket at some point and post a link.
1948 Chevy 1/2-Ton
I just looked in my '48 5-window. I can't see anything connected with the headliner that looks like that. You would need more holes in them to be used in the windshield divider.
Do you have a perverse friend who slipped some bogus items in your parts pile?
I have a lot of perverse friends, but they haven't slipped me any bogus parts.
I figure their use will become evidenet as the assembly continues. A possibility is that they're part of the glove compartment, or something like that. Or maybe some kind of stiffners up under the dash. ohwell
1948 Chevy 1/2-Ton
They look like the rails the window regulator rides in. Your windows won't roll up without them. Just a guess.
Tom R,
I agree with Robert door window guides
Brad
Tom, the parts in question are not windshield garnish mouldings. If they were they would have a holes approx' 1 1/2 from each end. It is hard to tell from the pics but if they have chanels running along each side for their full length they may be window regulator tracks.
  • 50 3100
  • 51 3100
  • 72 short bed
1950 Chevy 3100
In the original Gallery
More pix and update in the Gallery Forums
1952 Chevy 1/2-Ton Deluxe Cab
1957 Chevy 210 4dr
1957 Chevy Belair 4dr
1964 Nova 400 4dr
Hmmmm,
I don't remember headliner supports and regulator channels are at least 19" long and the edges are more curled. Let's keep guessing........
1948 AD Pickup
The regulators are the channels the windows roll up and down in, right? I have those, and they bolt into the doors at the top and bottom, and are a lot longer. Possible clues...I haven't put the door windows in yet, and much of the dash is unfinished. The bed is done, as is the front end (with the exception of the hood alignment). I haven't put in the headliner yet, either. I checked yesterday, and I don't see the parts being connected in any way to the glove compartment.
The seat is in, but I haven't put the cardboard on the back of it yet (I can't get the seat to move forward to do it). Maybe they're some kind of stiffeners for that?
1948 Chevy 1/2-Ton
They do look like an interior part of some sort because rust is minimal and alot of paint is still present, Still thinking........
1948 AD Pickup
just throw them out, then sure as shoot'in you'll need them and figure out where they really go. mystery solved!
as the saying goes "when in doubt, throw'em out!"
cheers
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd
1953 Chevrolet 1/2 ton p/u
1957 Oldsmobile 88 2dr hardtop
1959 B130 International one ton dually
I know they don't match your interior center front windsheild trim, but it is coincidental that that peice is identical in length, width, and shap as the one on my 50 3600. Only differce is mine has four screw holes not two. This item is to small to be used for anytype of structual support which is why I am quessing it must be a interior trim piece.
Junior Member
Junior Member
You can lead a horse to water but you can't make him drink.
Some 1947 & 1948 trucks used those strips between the rear & center headliner bows to keep the headliner from drooping.
These strips were secured to the headliner by 2 brass button ties.
The strips are not flat but rather they have a bow in them to match the contour of the headliner.
These strips were eliminated in late 1948.
If you are installing a new headliner they really are not needed.
http://shutter13.pictures.aol.com/d...uRwFk6TwEQPkRw2BvKZHHzG+ensscfD50300.jpg
Ex Hall Monitor
Ex Hall Monitor
BINGO, we have a winner. grin
Truckmaster5150, you da man!!! I found a set of pictures I took of the truck back in 1990 when I bought it, and one of them showed those buttons in the rear headliner piece!
http://s242.photobucket.com/albums/ff77/stovebolt48/?action=view&current=Notes020.jpg
The pieces are even bowed like you said. I was going to straighten them.
AND, you even answered my next question before I asked it - whether I needed to put in those braces with the new headliner piece. I was a little worried about how to get everything lined up for cutting the holes, but now I don't have to worry about it. Thanks!
I can drink now, having been properly led and having had my head dunked in the water.
wave
1948 Chevy 1/2-Ton
