Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (homer52), 118 guests, and 6 robots.
Topics128,281
Posts1,058,469
Members48,490
#237151 07/13/2007 3:08 PM
Anybody run a 245/75/16 on their Deco or AD?
I'm switching from the old 15" split rim to an '80s 8-lug 16" w/4" backspacing for my '46 3600. I was going to buy some new 215/85/16 for it but then my brother offered me a set of bfgoodrich Long trails in the size questioned. Running them in the rear wouldn't be a problem but the front could be. I set the new rim on the front and I have about and 1" of clearence on the tie rods and they sit below the rim edge. I'm thinking the only issue could be fender rubbing.
Tell me what size and brand you're running!
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
My comments won't help but I'm running 650-16 on my 49 half ton. The 215/85/R16 are good radial replacements for that tire. However the rims are too narrow for some tire dealers to want to put them on my truck.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I run 7:50x18 on my 1953 3600
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
They are going to be harder to steer unless you have added power steering.
Paint & Body Shop moderator
I like 8R19.5 tires on a 3/4, or especially a 1 ton AD.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
4OTF--Good point about the steering. Hadn't thought about that.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Hi,
I have some 235/60R16 front and 255/60R16 back on my 55 1st serie Chevy Truck half ton. Would be space for more but I think it's wide enough
Bernd
http://img266.imageshack.us/my.php?image=dsc04389ib8.jpg
Oh by the way, I did some work to give the tie rods more space. Don't think it would rub on the fender with the 245 though.
Bernd
I'll be running 255/70R16s in the back of my 1940 GMC, and 235/70R16s in the front. I will be using 6 lug artillery wheels that have been widened to 7 inches with 4 inches of backspacing. My custom rear axle is 61 inches wheel mount to wheel mount (2 inches wider than stock), and all the math says it will just fit under those rear fenders. I don't know yet because I haven't got my rims back yet, and I don't have the stepside bed on my truck right now.
Good Luck!
Should'nt need power steering. My trucks run 8.25 X 20's and they steer O.K., even with 8 tons on them,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I don't see where there would be a problem with the size overall, but there might be 2 issues. I'm under the impression you're running a wider rim, say about 7"? That would ok for the 245. Now here's the real problem, the Long Trails are too low of a load rating for that truck. If i recall correctly, that size only comes in a P rating, about the same as 4 ply in a bias. You're going to need at least a D rating, about 8 ply. I bet those tires came off of a Tahoe/Suburban/Yukon, right? That's an oe tire on them.
BTW-I'm running a 30x9.50x15 on mine, roughly the same width and diameter as a 245/75/16. No rubbing problems at all.
Bill Burmeister
I use a 7.50-16 on my 3/4 ton
Longbox55...you're right! The tires are off of a 2002 Chevy 1500 4x4.
Being the cheap guy, I'm using those used ones first till I can squander enough cash for some more original looking Power Kings or maybe some BFGoodrich Commercial TA Tractions.
The rims I have are 6-1/2" with the 4" backspace.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
I'm running 8R19.5's all the way around, on my '50 GMC 1 ton pickup.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Leo Offline
Moderator
Moderator
I am hoping to get some old style bias plies 6.50 x 16's. Or I'll try 225/85 x 16
