| | | Forums66 Topics128,096 Posts1,056,496 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 43 Member | | Member Joined: Jan 2006 Posts: 43 | during the winter i pulled the 350 motor from my 52 an made a 383 stroker out of it got rid of the 350 tranny an picked up a 700r from summit put it back together drove it to c my momma 212 miles away on 9 gallons of gas could not beleive it it runs saaweeeeettt just want to thank the fellers at this website 4 all the answered questions because i dont think i would of tried to tackle it if it wasnt 4 all the positive feedback
thanks again the kid | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I get about 10 mpg. and am very jelous. are you sure you wern't towed or trailered part way. | | | | | Joined: Jun 2007 Posts: 6 Junior Member | | Junior Member Joined: Jun 2007 Posts: 6 | I'm a newbie ... my 66 'burb has a 250 inline 6 with 3 speed. What kind of mileage can I expect? The gas gauge doesn't work, so the answer might mean me not getting stranded  | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Sounds like you have her SUPER TUNED ! ...congrats ! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 52chevykid: way to go man. I put the 700r4 in my pickup and while I have not checked the mileage I can tell I'm not fueling up as regular!!
52chevykid/others: while I am ashamed to admit this I have made a badddd mistake. I have disasembled the 52panel and did NOT make enough "reference points" for putting in the V8. I did make a mark where the front of the cab was in relation to the chassis. NOW, while I have the chassis off I want to blast it and put the engine,tranny on the chassis but need to know where to sit it. SO, can anyone measure me a "point to point" for locating the chev small block in my chassis and it be good when I bolt the body back on???? Please???? OK, I admit I made a mistake so don't crucify me to bad!!!!! | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The 700R4 is the reason for your good mileage.I am running a 350SB,with a 700R4 and 3:90 rear,and getting 20 MPG.The 4 th gear in a 700R4 is about .78 to 1 ratio,whereas the 350 turbo hydramatic is 1 to 1 in high or 3rd gear.What is the gear ratio in your rearend?Nothing like an overdrive tranny for fuel economy. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Achipmunk, Do you still have your transmission crossmember still in place? You can measure from the bellhousing mounting holes forward to the block to tell you where the rear edge of the engine will be. Just set the old bellhousing down over the holes to find the back edge of the block would work too, Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Scott, I understand what your saying. Right now the chassis is out from under the body and sitting in the yard. The original cross memeber is still on the chassis. Why didn't I think of that :hammering: So, as I understand it, the back of the old 6 cyl would be good for the back of the V8 and the distributor sitting in a good place. Thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The V-8 bell is very close, if not the same, in thickness as the 6's. If you run GM's HEI, you will still have firewall clearance problems. If you use a small cap aftermarket distributor, it should fit without modification. Good luck, Scott | | | | | Joined: Jan 2006 Posts: 43 Member | | Member Joined: Jan 2006 Posts: 43 | i believe the rear end gear is 373 not real sure cause i never knew what i was doin an no truck wasnt attached to anything on my trip i couldnt believe the mileage either | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | 52 Chevy Kid,That 23 MPG sounds about right with that gear ratio.Along with the fuel economy you should still be getting good performance.With a 700R4 you can go up to a 4:11 rear and still have good fuel economy and good pickup.when I put mine together I was gonna put in a 3:73 rear,but after the way the truck performed and the gas mileage,I just left the 3:90 in there.Way too many people changing engines,to get good perfomance and economy,when the real secret lies in the gearing. | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I don't know squat about transmissions or gearing, etc. Is a 700r4 a manual transmission? Will it help my 62 c-30 get better mileage? Will I need to change my differential? ??????? :confused:  :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The 700R4 is an automatic overdrive transmission.If you have a C30 you probably have a very high rearend,probably somewhere around 4:56.Anyway you can get that rear gear down to maybe a 3:42 will help on mileage,or better yet a 3:08.With the 700R4 it is about.78 to 1 ratio,whereas a regular 350 or 400 Hydramatic is 1 to 1 ratio. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A C30 will more likely have a 5.14 gear, which is a low gear, not high (higher the #, lower the gear). 4.56 was used in the 3/4 tons, though it did become an option on the later 1 tons. About the highest you can get for that diff is a 4.10, using a center chunk from a '68-'72 3/4 ton. If you want a higher gear, like a 3.42, you'll need to swap out to a later diff, like a GM corporate 14 bolt 10.5" ring gear, or possibly the Dana/Spicer 70. If you're looking to keep it manual, and want an overdrive, consider either the NV4500 or a Ranger or Gear Vendors add on overdrive. BTW-I only get about 12 mpg, IF I keep my size 14 out of it!!!
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I changed my rear ratio from 5.14 to 4.10, and was planning to go to an NV 5-speed as well, for the overdrive. But, having driven the auld girl for a while now with the new ratio, I've decided that I won't need the O/D unless I was to start logging a lot of miles on Epic #2. She's completely driveable now, where before she was screaming at anywhere over about 40 - 45 mph. Now, I could cruise at 55 - 60 all day. And while I haven't gauged fuel economy yet, I know there's a BIG difference. 1951 3800 Be the change you want to see. -hotshoe
