0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm doing a 4 wheel brake job on my '54 6500. I got down to where I needed to bleed the brakes today and talked my boss into letting me bring home our BG Brake Flush machine to do it. It's a fancy power bleeder more or less. It pumps brake fluid into the top of the master under pressure and catches it at the bleeders with a vacuum hose. First attempt and I had perfect pedal without loosing a drop on the floor. For the heck of it, I really put some pressure to the pedal and blew a line where I didn't see that it had rusted. I repaired the line and cleaned up the mess and re-power bled it. In about 15 minutes, perfect pedal again, no mess.
I'm so impressed, I'm taking my other trucks to work to power bleed them in hopes of getting a better pedal. I'll be on the look out for a cheaper DIY'ers model to buy for at home. I'll never go back to the "pump and hold" two man way of bleeding brakes, especially on the PITA AD truck brakes. Just thought I would pass along a tech tip for anyone who cares, Scott | | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | I hate using that machine at work. Mainly because the pay is too little. I've done a couple of disc brake conversions on 1966 Mustangs and for bleeding brakes it is a very useful tool. Sure beats pumping and holding. It turns a 2 person job in to one. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A Mighty Vac works almost as well and only costs $30 at Harbor Freight.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I used "Speed Bleeders" on my '50, 3604 Huck brakes and they are as solid as a rock, a one man operation and fast. The only down side is having to see when the fluid runs clear and having to keep an eye on the fluid level Also the set becomes a permanent part of the brake system. Figure on droppin' about $25 for a set, so if it’s a one shot brake job your fine. If on the other hand your doing a bunch of brake work you are no doubt better of with a more professional set up. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Where did you purchase the speed bleeders? Who makes or sells them? | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | We borrowed a bleeder from our local parts store and I think Jeff spent more time re-building the thing than it would have taken to just do it the old way.
Those Speed Bleeders sound pretty interesting though.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I'll bet a search for a past discussion of speed bleeders will yield some good results. I never heard of them until reading a forum here. I bought mine at O'Reilly's.
Although it is possible to turn brake bleeding into a one person job, I found it more like a "one person and a helping son" job. Like Denny said, you have to watch the reservoir level and when things run clear at the brake.
Brad, I see that Speed Bleeder has a website, but I'm certain I bought mine locally. I went to the FLAPS and found it in their selection of items marked HELP! I'm sure you've seen these items before- things like springs, bumpers, handles, etc. As I recall, mine were HELP! bleeders, sold in pairs.
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by 48bigtrucks: I really put some pressure to the pedal and blew a line where I didn't see that it had rusted. You make an excellent point. I've repaired two "blown" brake lines on my 38 that rusted at contact points until they couldn't hold the pressure. We all need to inspect our brake lines, especially where they are in contact with clips or frame components, for rust or wear. It's always better to make a mess in the garage than on the road.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Bah Humbug. All that new fangled stuff takes the fun out of a wonderfully messy job. And if you use those "one man" machines what do you use your wife for? I'll stick with the old time method and put that $$$ to good use on my vintage Air.
~Jim
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I will vouch for the "Speed Bleeders". Not really new fangled much at all. Just bleeder screws with thread sealant and a one-way valve. Been around for a long time.
I have them on my Mazda which runs road courses where I brake from 120mph to 35mph in 100ft etc., 3 to 5 times a lap. Brakes take a beating, much more than any stovebolt could dish out. I use the speedbleeders as you have to keep fresh fluid in the wheel cylinders, so you bleed the brakes about every 500 miles or so. I run 12" vented discs on all four corners with hats, 4 pot Wilwood calipers on the front, RX-7 calipers on the back, with race pads it will just about jerk your front teeth out.
I plan to put a set of speed bleeders on my Silverado next brake job.
I will admit, there is a certain quality to have the wife, girlfriend, or what not out to help bleed the brakes, but for pure functionality, they are better for other stuff and the speedbleeders are good for bleeding brakes.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
R-Bo
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | i've had a motive power bleeder for years. one of the better tools i've owned. works on hyd clutches as well...
they're a very simple and efficient tool. kind of like a pump up weed sprayer..
[img]http://tbn0.google.com/images?q=tbn:Q_63plFQnOI66M:http://www.volvoclub.org.uk/faq/ImagesProcedures/PowerMotiveBrakeBleeder.gif[/img] | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here\'s the tool that I used. Works great, but it took some time to configure a master cylinder adapter to seal to an AD master that's still under the floor. Just so you all know, Scott | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Originally posted by Avette4me: kind of like a pump up weed sprayer..
In fact they're so similar that there are plans all over the place to build your own using exactly that: http://www.bmw-m.net/TechProc/bleeder.htm | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Brad, I think your question was answered, but they are at most of the FLAPS on the “HELP” displays. Problem is they might not be the right ones for your truck. R-bo has provided you with a link to their site. They have listings for every model vehicle. I just drive down and pick them up, they have a shop set up on a farm about 10 miles south of me in Newark IL. It’s a small mom and pop operation but that’s all they do and they have a good distribution system setup. Looks a might bit expensive for a one time user Scott, tried to get a price but after 10 min. trying to access their site I gave up.
Robin, tks, that’s a nice little set up, easy to make and handy to have around, looks just like the setup that Evette posted.
Big, your absolutely correct, I’ve still gotta bribe my “Big old wife” into watching the catch bottle for clear fluid while I pump and watch the fluid level. I tried using a mirror but the bubbles are to small to see with out binoculars.
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Originally posted by Denny Graham: Looks a might bit expensive for a one time user Scott, tried to get a price but after 10 min. trying to access their site I gave up.
Denny Graham Sandwich, IL At my house, it won't be a one time use. Besides, I have "free" access to one. I was just stating how nice of a tool it was, wasn't recommending a personal shop to buy one. Maybe one could be rented. With a little inginuity, some one could easily make one, Scott | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I use a glass quart canning jar (ball brand - I think) at the end of a hose connected to my bleeder screw. Just put some brake fluid in the bottom of the jar and keep the master cylinder full. Pump away on the peddle.
Works for me.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I never cared for the power bleeding systems. If you have a leak it makes them a bigger one, and a mess to clean up. Although it would be nice wiuth the small master chevy provided for the big trucks and to use when you have a hydro-vac in the system. We just let gravity do most of the work. We didnt mind the 2 guy thing, but it is hard on the thread of the master having to refill it all the time. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i may look into one it sure would be handy 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | The BMW guy says 15 - 20psi for bleeding. Does this pressure apply to our brake systems too? I'd hate to over pressure and blow out a cylinder.
Bill | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Originally posted by TxLaTx: The BMW guy says 15 - 20psi for bleeding. Does this pressure apply to our brake systems too? I'd hate to over pressure and blow out a cylinder.
Bill 15PSI isn't even enough pressure to overcome the brake return springs holding the shoes back. Brake pressures are hundreds of PSI, this machine won't hurt a thing. BMW's have plastic and aluminum masters and our AD's have cast iron masters, couldn't hurt them if you wanted too, lol, Scott | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I agree with oldbluetruck. Use a jar, hose and pump away. Kinda keeps things in the vintage spirit around the garage. | | |
