1 members (Otto Skorzeny), 90 guests, and 2 robots.
Topics128,090
Posts1,056,380
Members48,442
#231802 04/14/2007 12:01 AM
Junior Member
Junior Member
has any one done this swap? how much modification is there?
Although I have not done the swap personally, "A.D. Engineering" (I think it's called) makes a mounting kit just for the swap you are considering. And it's located right here in Iowa I think.
Welcome to the Stovebolt. Where in Iowa are you from?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Junior Member
Junior Member
I am from urbana iowa just north of cedar rapids.
Junior Member
Junior Member
looked at the web site for that kit and it looks pretty easy. already have the frame painted and the engine brakets welded in I now will have to get the body ready. any one know a good place for aftermarket parts. 48bigtrucks where at in center point do you live.
Do you know where Fross park is on the north side? I'm across the street behind the cemetery. Where are you in Urbana? My sister, step brother and several co-workers live in Urbana,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Oh yeah, better get to the swap meet at Hawkeye Downs this week-end. That's where I'm headed right now. We should meet up soon,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Y'all should make your meeting plans by private message. This space is for talking trucks.
Thanks.
Relax Cletis, we're working on it, Geez,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
What engine is "normally" used in this project? Can I use a 235?
I looked at the website but didn't see this addressed.
Thruwurkin
Half Ton Will Travel
God bless America...One nation under God
#231812 04/16/2007 12:53 AM
I'm in the process of a 54 1/2 ton on an S10 frame. Going for a 327 but don't see why a 235 shouldn't work. Just got to figure out how to mount it to the frame.
I made my own mounts and have about $100 in the whole thing including a 14 dollar hole saw for the top plates. I think it can be done easily now that I've been through one. Thinking about a 1 ton Panel for the next one...
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Junior Member
Junior Member
dan, do you have to make many adjustments for the V-8?
There's a HUGEGANTIC thread on this very topic over in the Hi-Po Shop right now that has some VERY good info in it from the guys who have actually done the swap (or are in the process of doing it) and lived to tell about it.
Also:
I've seen an S10 with a 350 shoehorned into the engine cavity before. There isn't a whole lot of extra room, but it works without too much modification, as the S10 frame was originally designed to accomdate an SBC (IINM).
Most of the guys who do the S10 frame swap go to V-8 engines, it seems, but an I6 would be cool to see mounted in there. grin
