2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#229034 03/09/2007 11:42 PM
I am now at the point of getting ready to drive the full resto out on the road, and have not been able to find a hood safety latch for the 1953 3100 short bed. Does anyone know of a place to secure one of these babies, and does it really matter? The hood shuts securely as it is; I have tried to lift it and it is locked down tight! I have tried Mothertruckertrucks and all the usual suspects from the aftermarket dealers. But, maybe I am missing one. The latch bolts to the underside of the hood and is shaped like an inverted "L."
#229035 03/10/2007 12:06 AM
Thanks! I called them, and they said that they did not have that part and that it should not be on "the Internet."
Oh, well, valiant try!
Thanks again!!!!
#229036 03/10/2007 12:26 AM
I put a cable under the hood by the latch which dropped through the hole in the latch plate in front of the rad. I put an eye-bolt through the bottom valance and put a padlock on it. Easy access and especially comforting when the truck was kept in a garage away from here.
The cable had ferrules on each end and before putting them on I sleeved it in plastic. Simple and effective.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#229037 03/10/2007 2:16 AM
I'll be taking delivery of a truck this week-end that I may part out. After I inspect it further, I may have a secondary latch for you. E-mail me after Sunday to see what I plan to do with it. I have a few other hoods too that may have one on it, I'll check into it over the week-end,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#229038 03/10/2007 4:30 AM
That would be great!
#229039 03/11/2007 1:07 AM
In the meantime, go to any gun shop, and get one of those plastic-coated cable locks Big Brother makes them sell with every firearm. It should double as an emergency hood latch, and an anti-tampering device.
#229040 03/11/2007 2:09 AM
Shmoo,
Do you need just the actual lever, which is rivoted in, or the whole mechanism that's attached to the hood? The only hoods I have are from big bolts, so the whole thing won't work on your pick-up.
Let me know,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#229041 03/12/2007 2:16 AM
TTT
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#229042 03/12/2007 2:25 AM
I don't know which MotherTruckersTrucks you contacted but I am pretty sure that "Mothertrucker", the guy that used to be on here would have one for you. He hangs out on the GMC board.
1951 1 Ton Completed
#229043 03/12/2007 3:56 PM
Yeah, I had tried MT right off, to no avail. Anyway, the only thing I really need is the L-shaped piece that comes down from the hood. We have one, but it is bent up.
Thanks, Guys!
#229044 03/12/2007 6:52 PM
I've got one, I'll get back here tonight, after work,
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
#229045 03/12/2007 7:43 PM
1 Offline
Scott
By any chance would you have two ? mine all busted up too
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#229046 03/13/2007 12:21 AM
Sorry, I just lucked out and have a good one on a truck that I just bought yesterday. If that one would have been trashed, I wouldn't have any to give.
Drop "Iowa Trucks 59" a note and see if he's got one. I've bought some AD stuff from him in the past and I know he's bought more trucks since too.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
