| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | I am now at the point of getting ready to drive the full resto out on the road, and have not been able to find a hood safety latch for the 1953 3100 short bed. Does anyone know of a place to secure one of these babies, and does it really matter? The hood shuts securely as it is; I have tried to lift it and it is locked down tight! I have tried Mothertruckertrucks and all the usual suspects from the aftermarket dealers. But, maybe I am missing one. The latch bolts to the underside of the hood and is shaped like an inverted "L." | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Thanks! I called them, and they said that they did not have that part and that it should not be on "the Internet." Oh, well, valiant try! Thanks again!!!! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I put a cable under the hood by the latch which dropped through the hole in the latch plate in front of the rad. I put an eye-bolt through the bottom valance and put a padlock on it. Easy access and especially comforting when the truck was kept in a garage away from here. The cable had ferrules on each end and before putting them on I sleeved it in plastic. Simple and effective. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'll be taking delivery of a truck this week-end that I may part out. After I inspect it further, I may have a secondary latch for you. E-mail me after Sunday to see what I plan to do with it. I have a few other hoods too that may have one on it, I'll check into it over the week-end, Scott | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | In the meantime, go to any gun shop, and get one of those plastic-coated cable locks Big Brother makes them sell with every firearm. It should double as an emergency hood latch, and an anti-tampering device. Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Shmoo, Do you need just the actual lever, which is rivoted in, or the whole mechanism that's attached to the hood? The only hoods I have are from big bolts, so the whole thing won't work on your pick-up. Let me know, Scott | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know which MotherTruckersTrucks you contacted but I am pretty sure that "Mothertrucker", the guy that used to be on here would have one for you. He hangs out on the GMC board. | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Yeah, I had tried MT right off, to no avail. Anyway, the only thing I really need is the L-shaped piece that comes down from the hood. We have one, but it is bent up.
Thanks, Guys! | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | I've got one, I'll get back here tonight, after work, Scott | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Scott By any chance would you have two ? mine all busted up too Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sorry, I just lucked out and have a good one on a truck that I just bought yesterday. If that one would have been trashed, I wouldn't have any to give.
Drop "Iowa Trucks 59" a note and see if he's got one. I've bought some AD stuff from him in the past and I know he's bought more trucks since too. Scott | | |
