1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
Well I know it ain't neer as cold in my part of the country as it is in some of you other Bolters live, but around here it's been getting in the high 20's so I figured I better put some antifreeze in my bolter or else. Bye the way how cold is she getting in you Bolters part of town? :confused:
about 55 here now, should be close to 65.. had a little cool spell to come in,..........
high 20's in calif..........
Redryder pix
My Hotrod
It gets a bit chilly in the deep dark part of the night, in the middle of the dead of winter here.... but, not enough to crack my block...
Cool-O-rado will be a differnt story me thinks!!
Another quality post.
Real Trucks Rattle
18 this morning in South Dakota.
Antifreeze helps your engine cool too. I thought everybody ran antifreeze year around.
Jed Offline
Low-mid 20's in the mornings here in Cool-O-rado, Rusty.
I'd venture a guess that Buddy in AK is already seeing it a whole lot worse than all of us.
Ex Hall Monitor
Ex Hall Monitor
Mid 20s this morning. I run anti-freeze all year for the anti rust protection plus as noted above it cools better than straight water.
Haven't got to the 30s yet here in Azle 11 miles NW of Ft.Worth yet, but I do run a good mixture so I don't have to worry if it gets to mid 20s, which it will before spring. Nice to hear from everyone around the world though. "God bless our troups and hope they return home safe". Like it or not. Neal
18 for the low, 39 for the high and winds that will chill you right down to the bone. I run anti-freeze year-round too. I forgot to get some in an old Monte Carlo once, had to throw that engine away,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Antifreeze raises the boiling point, but it is harder to change the temperature of water than any other liquid: so I wouldn't say that antifreeze cools better. A wetting agent can improve cooling, however.
We've got six inches snow already. Went around and checked all the vehicles for antifreeze strength. It's got to be good for around -35. Get's alittle cold here in winter.
38 original
48 panel
59 stepside
46 in the back forty
Antifreeze? wink
Like most everybody has already posted, I use antifreeze year round. It raises the boiling point of water, which helps with cooling as the radiator won't boil over as easily, and it provides corrosion protection, which is very important for your radiator.
It's only dropping into the forties here and raining.
58 Fleetside, 235, "The Old Buckin' Bronco"
13 when I got up this morning with a nasty wind chill.
