5 members (Gray_Ghost, Maybellene, Gdads51, TUTS 59, Hanks custodian), 77 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#215497 09/11/2006 12:39 PM
Need some advice.I want to install new front wheel bearings in my 53 3100,should I use the ball or the roller type ? Thanks DON
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#215498 09/11/2006 12:43 PM
From what I've heard the roller type bearings are better than the old ball type bearings. You'll have to replace all the bearings and seats.
I just pulled my front hubs this weekend and found my bearings in need of replacement. However, I don't know if they make them for the 1 ton's or not.
#215499 09/11/2006 2:08 PM
Tab Offline
I had lots of front wheel bearing problems in the past. A guy at a local auto parts looked up some roller taper bearings for my 62, 3/4. He had a very hard time cross referencing though and one of the bearings was not Exactly the right width. I never made the swap because of the expense and unknowns. What I did was mix two greases (regular old yellow grease and white lithium grease) which made the grease less viscous. I then packed the crap out of them so much so that grease was oozing past the seals but I didn't care. So far so good. Standard grease is to thick for those ball bearings.
delete my account and pictures
#215500 09/11/2006 7:05 PM
Roller bearings no question about it. The grooves they carve in the highways will tend to eat up the ball bearings too.
Rollers have a higher load and side load capacities.
#215501 09/12/2006 12:45 AM
The rollers are more tolerant of the side forces from radial tires better, too.
Bill Burmeister
#215502 09/12/2006 1:54 AM
After talking thouroughly with the guys at the bearing place that I bought mine at they said no to the tapers and I went with ball bearings. No complaints. I believe most problems with balls are due to incorrect installs or being slightly misaligned. Just my thoughts.
Jeff
My 1953 Chevrolet
1947.1 Gallery
#215503 09/12/2006 3:29 AM
Not long ago I "posed" the same question but most were saying why not use the ballbearings as they had lasted all these years. I see some logic there if, as someone mentioned, they are properly tightened etc. I ended up going with the ball bearings and have no regrets but I think I really like the taper ones better. I'm sure either one will work OK its just that we are always wanting to make our trucks better and last longer. I think I will go tapered on the one I'm working on now though since they may be more readily available and more economical in the future should replacement become necessary.
#215504 09/12/2006 4:25 AM
I had the same question....that is until I found two NOS inner fronts for my 52 3600. Got em both for $15.50. Carter wants $65.00 apiece! Now if I can just find the outers...!
