1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I really like my 454, bigger is better you know, Scott | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I have always liked the old 350's but the old 427 wasn't bad either. | | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | | | | | | Joined: Jun 2005 Posts: 38 Member | | Member Joined: Jun 2005 Posts: 38 | Air cooled VW engines, the 40hp 1200cc in particular, though any year or hp rating will do. Keep the timing set properly and watch those exhaust valves.
Toyota 22R
VW 1.8L water cooled 4cyls, my 83 GTI had 340,000 miles on it when I sold it, never burned a drop of oil....leaked it, thats a diffent story.
Cummins 5.9L 6cyl and its 4 cyl 3.8? equivalent. These motors will run forever if maintained properly. I've seen the 4 cyl version in industrial applications with 12,000 hours on them.
5.3L Chevy V8. My parts running truck at work is a 99 Silverado with 234,000 very hard miles on it and still runs like new. I am beginning to think this is the best V8 Chevy has made to date.
Volvo 5cyls from the early 90's. I've seen quite a few with 300K miles on them running strong.
Mercedes diesels, same as the Cummins diesels. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have not seen one yet, but I think I would like a Detroit Diesel 12V53 with two or perhaps 4 turbos. Then to make it even better it would be a silver model (bypas blower and crosshead pistons) and also DDEC (electronic controls / injectors)
They did actually make a few V12 series 53 Detroits, but less than 20 I believe.
More practicaly I would like a silver, electronic, 4-53TI Grigg | | | | | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | My favorite would half to be the old screamin' 671 detroit. they ran forever as long as ya kept em wound tight and they blew oil everywhere. Used to really [censored] folks off when they would blow by me on a hill and almost everytime I'd catch up to em at the stop light in the next town. As for gas engines, its a tie between the 283 and the 2.5 4cyl in my 89 ciera.... | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | How about the Mercedes 5 cylinder 3 litre turbo-diesel. Iron block and head, run forever, will push a 4000 lb car all day long at 80 mph and give 28 mpg (speaking from experience).
Royzell | | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Hard to beat a Briggs & Stratton in any shape or form.
I have a 283 in my 54 truck that I rebuilt with all new components and tons of machine shop work.
I have another 283 on the engine stand for my 46 ford.
But...
I have two 327 small journal blocks that I might ditch the 283 in my ford for.
If I had a tight budget though I'd get me a 350 block and a rebuild it with a $169.00 rebuild kit from Northern.
Depends on personal preference.
It makes you wonder if someday all of the "different" motors will be forgotten due to lack of knowledge.
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Last year we finally overhauled some hydraulic power packs (3) at work. They were 1961 model three cylinder (373?) Detroit Deisels. They have been running more or less 12-18 hours a day since they were put in service in the early sixties. They slobber oil out the exhaust, but they start every time...would have to qualify as one of the best engines of all time. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | they would be 3-71 Detroit diesel's your choice of the two stroke series (displacement per cylinder) are 51, old and hard to find 53 71 92, only made in v type 110, only made in an inline 6 149, only made in V type | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Rebuilt a Lincoln Zypher V12 years ago that was a VERY interesting motor---BUT the 235 in my '56 runs so well, ya gotta love it!  | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | 4 cyl Offenhouser was baned from Indy. Can't beat them. | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | From 1955 to 1961 in Canada, Pontiac put a 261 cubic inch inline 6 in there cars as the basic engine. Imagine how dead that was in a full size 1961 Pontiac (big heavy car!) However, a nice engine for an AD truck Ter | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Let's see.... Piston? No real favorite, but the Max Wedge looks pretty cool. Love my 216! (RR Merlin, but I'll never own one)
Turbine? P&W 123. Bullet-proof and dependable up to 140% rated torque pluss awhole bunch (gauge stops at 140)
Straight jet? PW JT8D. Developes power AFTER shedding a bearing through the turbines! (Seen it) Both of the above have carried my butt through thick and thin.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | Well... 36hp VW 1100 22R toyota - hit 200,000 this past weekend! 5.9 Cummins 22? slant six honda 750 Four Of course my 216 and 235 stovebolts | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Chevy: 350 (341,237 miles on her and her only problem is smoking) Dream engines: ZZ572, 427, 454
Ford: Boss 429 | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think my favorite engine is one I haven't got yet. But it will be a total screamer and a chevy. | | |
