11 members (Rusty Rod, klhansen, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 3800GUY, Oswald, Wally / Montana, 1 invisible),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 26 | Where, in your experience, is the best place to get a new battery for my truck. It is still original 6 volt. The battery in it didn't like the cold this morning and my truck wouldn't start. I assume it's the battery. If you have other ideas, let me know. Thanks, Jerod.
'50 Chevy 3600
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I usually get them at Sam,s club or Carquest. The battery specialtie shops are also good. With 6 volt system the whole combination is important. The plugs & points. Make shure your battery cables are heavy gauge & connections clean & tight. After it is running check the charging voltage. It should be 7-7 1/2 volts. Your choke cable needs to work good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Tractor Supply (TCS, Campbell's) stores would work. You might want to try and find an 8 volt battery. You can us it in you 6 volt system and it will give you a little more zip when starting. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I get mine at a local farm supply store for about $35. They are pretty old technology but still last me 3-5 years of daily driving, including this morning at 15 below. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i've gotten my 6 volt battery from Agri-Fleet its for my ferguson tractor in my experiance i do not like 6 volt systems and i would like to switch my tractor to a 12 volt but i do not know if its is posible cause it doesn't start to well even when its 80 degrees out and in the winter it don't have a prayer 5 cranks our so and its done, but 6 volt batterys don't last me to long cause i have to crank on em so much so lot of times i just have to pull start my tractor then it fires up fast and perfect every time Nate | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | JRod,
Since I'm not familiar with any of the farm supply stores being in Boulder, and the closes one I do know of would be in Longmont...
I would suggest that you just head over to Checkers, Auto-Zone, or one of those other chains that I know are there.
They should have one sitting on the rack, just waiting for you. Probably around $40-$50. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Geez, what a deal!! I write the above post and go to make a run in my '48 after sitting for 6 hours. Doesn't start and the battery goes down trying!!!! I should have kept my mouth shut.
12 volt seems like a mighty fine idea.
(I drive only three miles to work so I think there hasn't been enough charging time in the cold, cold weather. I think we'll look for a place out of town.) 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Wally - 3 miles should recharge it after a normal start. or ya need a 6v alternator - should put a battery blanket on to keep that sucker warm down there under the floor, 6v battery's do take a worse hit from cold, in my experience - might be part of the reason they moved the battery to the top of the engine compartment! Bill | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Originally posted by OldIronChevy: i've gotten my 6 volt battery from Agri-Fleet its for my ferguson tractor in my experiance i do not like 6 volt systems and i would like to switch my tractor to a 12 volt but i do not know if its is posible cause it doesn't start to well even when its 80 degrees out and in the winter it don't have a prayer 5 cranks our so and its done, but 6 volt batterys don't last me to long cause i have to crank on em so much so lot of times i just have to pull start my tractor then it fires up fast and perfect every time Nate It sounds like your tractor needs a new set of battery cables, of 2/0 gauge. The 4 gauge 12 volt cables are too light. Heavy gauge battery cables not only start the vehicle faster, they loose less power to heat, which can be about half of the cranking power of the battery when starting.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Benn buyin' mine from Sam's Club for the last eight years or so...
Just make sure you get a Group 1 if your battery is still under the floor...Group 2 battery won't fit in the battery holder...
Sufficient battery cables are critical: no smaller than #2...#0 or #2/0 is even better !
Never had cold-start problems with my six-volt Bolts...rather the opposite: darn 235s won't crank when they're hot !
Good luck !
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | napa.
if they didn't have it on the shelf, they had it there the next day.
not as inexpensive as some of the farm impliment houses, but they are getting harder to find in my neighborhood. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My FLAPS carries them. No ordering necessary. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Every time I got another stovebolt,I've always bought the biggest,baddest six volt I could make room for from NAPA.Never had a start problem on any of 'em,hot or cold. Speed | | | | | Joined: May 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 26 | Thanks for all the input. Warmed up enough that I got my truck started this morning. I'm thinking about getting an Optima battery. Any thoughts on them? (I also noticed that there is a thread in the Electrical Bay about them)
'50 Chevy 3600
I got one in the newer of my 52's. Seems to be a good battery. Previous owner said it's been in there for at least 6 years that he knows of, and it starts the truck up everytime I've tried.
It's smaller than the regular 6-volts though, so you about have to figure out a tie-down method, so it aint bouncing around down there. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Optimas are great.
Make sure you have the proper size battery cables - undersize cables will cause all sorts of headaches. | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | I've got a 6v Optima in a 41' pickup,... No complaints, other than high cost. I hope it last a little longer than a standard wet battery. Wouldn't fit the battery box. Have heard it will fit diagonally, but I had to trim a little tab off the bottom of the battery to mount it. No harm done and been running it about a year now. If I remember its about 850 cca.------------- Tony
1941 AK named "PETEY" my buddy.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I just wanna say that if your 6 volt truck won't start fairly easy in -15 degree weather, there's something wrong with something and it ISN'T the fact that you're running a 6V system.
Points, plugs, wires, cap, rotor, coil fuel system, carb.. check all that stuff.
Sitting face in the wind with -30+ below wind chill and -15 degree ambient temp my '46 1/2 ton pops right off with a 6V battery that I bought a year ago from my local farm store.
Yea, it dosen't turn over nearly as fast as it does when it's 80 outside, but within 3 revolutions she's running.. and my truck is a piece of crap.
So if you have to crank and crank, [censored] with the choke, slaughter a chicken on the hood and recite some sort of swahilli witch doctor chant while wearing a straw skirt to get your truck to start, your problem can't possibly be that it's because it's a 6V system.. it's because it's a 6V system that isn't properly maintained.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Before you fix the truck, do a video of the swahili witch doctor chant in the straw skirt. I'd really like to see that!!!  | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Fumblin,
I always enjoy your posts... You're very good at painting a picture. And they're easily translated into video in my mind.
But I gotta say, I'm with Rich, I want to see the real video.
Tweak, I don't know that anything was trimmed off mine, but it does sit in there at an angle. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "So if you have to crank and crank, [censored] with the choke, slaughter a chicken on the hood and recite some sort of swahilli witch doctor chant while wearing a straw skirt to get your truck to start, your problem can't possibly be that it's because it's a 6V system.. it's because it's a 6V system that isn't properly maintained."
This should go into the Hall of Fame of Basic Stovebolt Truths. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | [img] http://www.oldtruckstuff.com/voodoo.gif[/img] ....for those who don't have vivid imaginations.
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Hey that's the witch doctor from Scooby Doo, ain't it? And is he working his magic on a Dodge?  Good stuff, as usual, Frank. LOL | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Tweak, as long as your wiring is in good shape (no low-level shorts), an Optima will last a long time. In a problematic wiring system in my '77 Corvette, an Optima lasted about 3-4 times longer than a standard wet-cell battery (I've since purchased another Optima, and figured out the problem). | | |
