2 members (Peggy M, Gdads51), 106 guests, and 3 robots.
Topics128,169
Posts1,057,043
Members48,458
#182728 01/17/2005 9:35 PM
Can somebody give me some suggestions about fuel tank i can put under my truck? I have heard a suburban tank of the same year will fit but they are scarce in this part of the country.
#182730 01/17/2005 10:04 PM
Moderator
Moderator
This has been discussed before. Search the archives and see what you find. I seem to recall somebody finding a plastic one at the tractor supply or farm store that was just right.
I found a replacement tank for my '47 panel from another 'bolter by carefully combing the swap meet. $50.00 and I met a great guy.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#182731 01/17/2005 10:06 PM
Moderator
Moderator
Joe, I thought nobody sells an under the floor replacement, but only the in-cab tanks. Has that changed?
BTW, Joe is the great guy I was talking about.
Burma-Shave (1947)
#182732 01/17/2005 10:23 PM
LMC only sell in cab tanks. www.brotherstrucks.com.sell under bed but they run around 500.00. www.fatfenderedsteetrods.com sell under bed also.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Early Classic Enterprises also has one, and then there are two or three companies that advertise in the back of Classic Trucks magazine.
I bought an 80's blazer tank that would require removing the rear most crossmember (holds 26 gallons) but decided against it and had a buddy make me a custom one out of polished stainless steel.
Sittin' Pretty in My Old Kentucky Home.
http://www.picturetrail.com/barneysbowtie
Blu64, I don't know about your particular model but I was visiting a buddy of mine yesterday who has a 49 pickup and he used a tank out of a chevy van.((70's to mid 80"s??) I believe he said it was a 20 or 22 gal tank. He only cut a small piece out of one of the cross members near the chassis where the tank corners could go up some and the rest of the tank would be flush with rest of the crossmember. It sure was snug and looked good. The cost....$20. I may try one in my 37?....just FYI.
I just recieved a GOLDEN STATE catalog and they show only inside fuel tank. A bit pricy @$200
brdsb3381
Actually,
I'm a dealer for LMC Truck, and we just came out with Under the bed ones. check the brand new catalog.
GO RANGERS grin
Photos Updated so check them out!
Hardy,
That's the tank I'm going to put under my 63. Do they list the one or two line sendor instead of the three and four style? I know I could modify one to work if need be.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Junior Member
Junior Member
I'm using a F**d mustang tank on my 53 3600. Fit is easy if you move the back crossmember. Mine is a flatbed, so I don't have to screw around with putting the fill hose thru bed...... mine will go out the back below flatbed. If you have a regular bed, I've seen 'em mount a fill door in the fender, but that certainly wouldn't look original........... kinda depends on what you want. My main concern was getting the tank out of the cab.
#182740 02/05/2005 11:39 PM
In reply to the mustang tank... I have one of these on hand but wasn't sure how to wire the gauge. Any help? Thanks for your reply.
