0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Can somebody give me some suggestions about fuel tank i can put under my truck? I have heard a suburban tank of the same year will fit but they are scarce in this part of the country. | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | This has been discussed before. Search the archives and see what you find. I seem to recall somebody finding a plastic one at the tractor supply or farm store that was just right.
I found a replacement tank for my '47 panel from another 'bolter by carefully combing the swap meet. $50.00 and I met a great guy.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Joe, I thought nobody sells an under the floor replacement, but only the in-cab tanks. Has that changed?
BTW, Joe is the great guy I was talking about.
| | | | | Joined: Jan 2001 Posts: 55 Member | | Member Joined: Jan 2001 Posts: 55 | Early Classic Enterprises also has one, and then there are two or three companies that advertise in the back of Classic Trucks magazine.
I bought an 80's blazer tank that would require removing the rear most crossmember (holds 26 gallons) but decided against it and had a buddy make me a custom one out of polished stainless steel. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Blu64, I don't know about your particular model but I was visiting a buddy of mine yesterday who has a 49 pickup and he used a tank out of a chevy van.((70's to mid 80"s??) I believe he said it was a 20 or 22 gal tank. He only cut a small piece out of one of the cross members near the chassis where the tank corners could go up some and the rest of the tank would be flush with rest of the crossmember. It sure was snug and looked good. The cost....$20. I may try one in my 37?....just FYI. | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I just recieved a GOLDEN STATE catalog and they show only inside fuel tank. A bit pricy @$200 brdsb3381 | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Actually, I'm a dealer for LMC Truck, and we just came out with Under the bed ones. check the brand new catalog. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hardy, That's the tank I'm going to put under my 63. Do they list the one or two line sendor instead of the three and four style? I know I could modify one to work if need be. Scott | | | | | Joined: Oct 2001 Posts: 2 Junior Member | | Junior Member Joined: Oct 2001 Posts: 2 | I'm using a F**d mustang tank on my 53 3600. Fit is easy if you move the back crossmember. Mine is a flatbed, so I don't have to screw around with putting the fill hose thru bed...... mine will go out the back below flatbed. If you have a regular bed, I've seen 'em mount a fill door in the fender, but that certainly wouldn't look original........... kinda depends on what you want. My main concern was getting the tank out of the cab. | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | In reply to the mustang tank... I have one of these on hand but wasn't sure how to wire the gauge. Any help? Thanks for your reply. | | |
