1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | O K I am finally going to get the concrete poured for my new shop tomorrow. The weather has not been cooperating. The building will be delivered Monday. I looked at a lot of building kits before I bought this one. I am going for strength over cheap because I have been through two tornados. I will update when I start putting this all togeather. It will take a while because I work at my business five days a week.
I like old trucks
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Bullet: I'm looking to add a workshop garage also, I'd be interested, if you were willing to share, what/why you ended up buying. I thought modular,pre-built or a kit would be a good option, but I'm having trouble finding good sources. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I'm getting a 30x50 pole building but they put the building up first then pour the concrete. I thought this sounded a little backwards. the reason is the county requires 18" diameter holes for the poles and that would cause them to infringe on the floor area. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | You will also be able to control the curing speed of your concrete. It will dry a lot harder with less chances of cracking not being exposed while drying. You basically want it to dry slow.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I went with a pole barn that I finished off myself. I had the Company build the basic barn and after the final inspection, I walled off a third of it, poured the concrete 7 inches thick with 1/2 inch rebar, put in eight inches of insulation and a furnace to work year round with. It's home away from home with a 4 speaker stereo and 27" TV with all of the movie channels. Only need the house to shower in and to sleep (and to "see" the wife), Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Just finishing a 30x40 block building with a suspended ceiling(did ceiling myself..and wiring). I checked around and after putting in most of the stuff the pole/metal buildings don't come with I found I came out much better dollar wise. I think the big factor to most of us is how much we can do ourselves to save money. No one usually mentions money here but with the 2x4 lay in lights, accoustical ceiling (insulated), 2 big garage doors(and intrance door), work benches and shelves built and covered with galvanized metal, air lines piped and a good size concrete area outside the shop for a total bill around 16-17K. Heck, I've waited so long I even painted the floor. Was I dreaming or will you have more/less in you metal or Pole buildings when they are COMPLETE?? Biggest chunk was the concrete which is going up 6 more dollars a yard in January to $80 a yard. (and the two truck loads of rock dust to take care of the elevation!) I also suspect building codes and cost of material in our respective locations has a lot to do with it? | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | My wife wants a pool... I want a shop... don't have the funds for both. What to do?
Kevin | | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | Get the pool...when she gets tired of it in 6 months you can fill it in and pour a slab over it for your shop. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Been there with the pool, but then I'm in WA. We used the hot tub portion more than the pool. Too darn much cleaning, etc. You know the difference between a pool and a boat? You can sell the boat. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | The company I work for is in the real estate appraisal business. We often decrease the market value of a home if it has a pool. You could build a shop over a pool; you would have a great pit for working under the truck.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I bought a 30 x 40 metal building kit here locally, it was a bolt together. The main problem I had was the concrete contractor made my building 2" too short on one side so he had to go back and pour a ledge with rebar and the whole thing , I was ready to kill him before it was all over, seems his dopehead son ended up being the one who laid it out.[Should have done it myself]. All in all it went pretty well after that incident and I am enjoying it very much , but as you will here from most guys here "My shop still isn't big enough". | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I got my building from World Wide Building Corp. in Peculier Missouri. I looked at a lot of others but this one looked the strongest. I dont know how it stacks up money wise. I built a pole building about twenty five years ago and now I am getting some rotting problems. I guess it should'nt matter since I am 65 years old but I like to think I am building for the future as well as for myself.
I like old trucks
| | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Update. I got my building unloaded and put where I want it. Now I have the shingles. No fun. I have them in my ear, face, and mouth. Doc says it can last four to six weeks. Oh well, I am getting a lot of rest.
I like old trucks
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I feel for you, I had shingles when I was 20, wouldn't wish them on my worst enemy. Put me down for over a month, get well soon. Brian | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I was wondering what ole bullet meant when he said he had the shingles. Why does he need shingles to put on top of a metal building?  Get well soon my friend and let us know how the building turns out. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I have had my foot in my mouth a lot of times but never shingles.I have wondered why they call them that but it feels like I have splinters in my teeth. The pain is not unbearable but it never stops. I have been hurt worse so I know I will survive. I have my building all put where I want and my son in law tarped it down for me so I will just have to be patient. My kids are good to help me when I need it.
I like old trucks
