5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#172026 02/25/2005 12:55 AM
I'm undecided about whether to keep my flip-up hood vent on 53 chevy pickup. Are these a big source of leaks or other problems?? I'm trying to keep as much of original look as reasonable but am willing to upgrade/improve where appropriate. It would be easy to eliminate with a little welding and fab work but I kinda like the look of it. Opinions/ideas appreciated.
'53 chevy 3/4 ton
#172027 02/25/2005 1:47 AM
I vote for keeping it. You can get a new gasket for next to nothing. I think they are a cool feature.
Rick
#172028 02/25/2005 2:01 AM
You gotta keep it. That's one of the coolest things on these old trucks. With a new gasket there's no way it'll leak. Besides that it is very functionable on a warm day.
#172029 02/25/2005 3:16 AM
Better than AC!!....Keep it! I love mine.
#172030 02/25/2005 3:59 AM
Speaking of the vent, has anyone come up with a clean routing for the drain hose so it doesn't drain on the valve cover?
#172031 02/25/2005 4:05 AM
I'm going to just lengthen the rubber hose and let it drain onto the ground
'53 chevy 3/4 ton
#172032 02/25/2005 5:15 AM
I put a new gasket on mine ... with the windows open and the vent open, it's amazing!
grin
Keep it!
I put the standard drain hose on mine (NO leaks EVER) and then put 1-inch wire loom over it, making it longer and making it look better.
I also painted the grill flat black ... when it's in the full open position I think it adds to the looks of the truck BIG time!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#172033 02/25/2005 5:47 AM
Im keeping mine too! Carpet's not in yet, so I ran the hose longer and it drains above the transmission.
I like the idea of black insert, Flying Tigers would look cool too! (Shark teeth like on ww2 aircraft)
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#172034 02/25/2005 5:22 PM
Keep it. You gotta man. I agree that with the windows down and the vent open cruising down the road it works great. I just replaced my gasket and haven't had a problem with leaking.
-Chris
Chris 1955FirstSeries
#172035 02/25/2005 5:40 PM
it also incourages one to keep the floors clean. ron the practical one.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#172036 02/25/2005 10:45 PM
Apprentice
Apprentice
KEEP IT! They work great.
fifty-one half-ton
#172037 02/26/2005 12:48 AM
Keep it!
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#172038 02/26/2005 3:10 AM
That's one of the feature of the truck that I like best. I spent hours disassembling, cleaning painting and reassembling that thing. I'm glad I did when I drive it in the summer. My truck is black and has no heat barrier on the floor. It's like sitting in an oven at a stoplight,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#172039 02/26/2005 3:23 AM
Junior Member
Junior Member
I definately say keep it!! I really like the idea of painting some teeth or flames or something on the grill-just something subtle though!!
aaahh..the smell of my old truck...
#172040 02/26/2005 5:40 AM
You gotta keep the crotch cooler. ;-]
#172041 02/26/2005 7:04 PM
I'll join the ranks and say keep it. I also have the side vent on my 49 and it sure is nice to have that cool air. Most are covered with something but heat still gets thru. I saw one on a truck and someone had lettered "GM Factory Air" on the screen. I read somewhere that there were originally 74 holes in the firewall for various hoses, wires and such. I used a piece of heater hose on the vent drain and carried it thru to the ground. If you do that run the hose thru the firewall hole and it will line up almost exactly with the spout.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
