0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I'm undecided about whether to keep my flip-up hood vent on 53 chevy pickup. Are these a big source of leaks or other problems?? I'm trying to keep as much of original look as reasonable but am willing to upgrade/improve where appropriate. It would be easy to eliminate with a little welding and fab work but I kinda like the look of it. Opinions/ideas appreciated.
'53 chevy 3/4 ton
| | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I vote for keeping it. You can get a new gasket for next to nothing. I think they are a cool feature. . Rick | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | You gotta keep it. That's one of the coolest things on these old trucks. With a new gasket there's no way it'll leak. Besides that it is very functionable on a warm day. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Better than AC!!....Keep it! I love mine. | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Speaking of the vent, has anyone come up with a clean routing for the drain hose so it doesn't drain on the valve cover? | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I'm going to just lengthen the rubber hose and let it drain onto the ground
'53 chevy 3/4 ton
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I put a new gasket on mine ... with the windows open and the vent open, it's amazing! Keep it! I put the standard drain hose on mine (NO leaks EVER) and then put 1-inch wire loom over it, making it longer and making it look better. I also painted the grill flat black ... when it's in the full open position I think it adds to the looks of the truck BIG time!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | Im keeping mine too! Carpet's not in yet, so I ran the hose longer and it drains above the transmission. I like the idea of black insert, Flying Tigers would look cool too! (Shark teeth like on ww2 aircraft)
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Keep it. You gotta man. I agree that with the windows down and the vent open cruising down the road it works great. I just replaced my gasket and haven't had a problem with leaking.
-Chris
Chris 1955FirstSeries
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | it also incourages one to keep the floors clean. ron the practical one.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2004 Posts: 29 Apprentice | | Apprentice Joined: Jul 2004 Posts: 29 | KEEP IT! They work great.
fifty-one half-ton
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | That's one of the feature of the truck that I like best. I spent hours disassembling, cleaning painting and reassembling that thing. I'm glad I did when I drive it in the summer. My truck is black and has no heat barrier on the floor. It's like sitting in an oven at a stoplight, Scott | | | | | Joined: Jan 2005 Posts: 8 Junior Member | | Junior Member Joined: Jan 2005 Posts: 8 | I definately say keep it!! I really like the idea of painting some teeth or flames or something on the grill-just something subtle though!!
aaahh..the smell of my old truck...
| | | | | Joined: Apr 2001 Posts: 23 Member | | Member Joined: Apr 2001 Posts: 23 | You gotta keep the crotch cooler. ;-] | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I'll join the ranks and say keep it. I also have the side vent on my 49 and it sure is nice to have that cool air. Most are covered with something but heat still gets thru. I saw one on a truck and someone had lettered "GM Factory Air" on the screen. I read somewhere that there were originally 74 holes in the firewall for various hoses, wires and such. I used a piece of heater hose on the vent drain and carried it thru to the ground. If you do that run the hose thru the firewall hole and it will line up almost exactly with the spout. | | |
