1 members (TUTS 59),
55
Mod | | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Well I decided to pull the engine and work on it this winter in the garage. So now I'm interested in a rolling engine stand, one that you can rotate the motor 360. I've seen them on ebay, new 1500 lb for less than $50. I expected them to be more expensive. Are these just what I need or junk? What do you think? Bill | | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | For that kind of money, I'd be leary. With all the weight it is going to support, I would rather see what I am getting. Besides, what you save in cost will most likely be spent on shipping. Also, if you are going to support a straight 6, you might want to make sure that it is long enough to remain stable. What works fine for a small block V8, might not be ideal for a longer, maybe even heavier straight 6.
Just my opinion.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you can find a stand at most parts stores that will hold 1000 lbs for about 60 bucks. If you want a wider "stance" consider buying one with square tubing and then add a bigger, or smaller, tubing to the existing tubing on the inside or the outside. Heck, you could even drill hoses in and make it adjustable. This is also how a lot of guys make a rotisserie for holding the bodies for blasting etc. This is just to get your gears turning!!! | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | 4 wheels is better than three. Can't tell you how many times I almost dumped an engine on my old 3 wheel stand. I think Blackhawk make a nice, heavy-duty wide-stance stand.
Looks like Northern Tools has some neat stuff. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I've used a couple of three wheelers for engines and currently have my 4t6 frame mounted on them. It works fine as long as you have a couple people flipping frame. Four wheels and a wider stance would help in either situation. Pics below Dan http://rides.webshots.com/photo/2951450480071274430qeOjmO | | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Thanks guys, I guess you get what you pay for is the truth. I'm looking at a 1500lb folding stand at Northern Equip for around $90 + shpg. It is 4 legged and looks pretty sturdy and I've had good luck dealing with them in the past. I like the folding design as there's not much room in my shop as it is. Thanks again! Bill | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | I bought a enigne hoist that came with an engine stand as a kit for just under $200.00 at Kragens. It worked great and the stand had four wheels. Im satisfied. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I bought mine from O'Reilly for about $50. It has 4 wheels and works great.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I tried to find one that would let me cradle and run a 235 engine. Wound up buying some 2" square tubing, steel casters and fabricating my own. Have about $75. bucks in materials in it. Have a pic in my "Tips and Tricks Webshot album.
I just retrieved my rebuilt 235 yesterday and although I had to make a couple "adjustments" it provides me with a sturdy platform with great access. If anyone is interested, I can provide the dimensions.
Dave | | |
