Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, baldeagle, NJC, Charles in CA, 1 invisible), 39 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#158467 11/02/2006 1:23 AM
Junior Member
Junior Member
Well I decided to pull the engine and work on it this winter in the garage. So now I'm interested in a rolling engine stand, one that you can rotate the motor 360.
I've seen them on ebay, new 1500 lb for less than $50. I expected them to be more expensive. Are these just what I need or junk?
What do you think?
#158468 11/02/2006 3:59 AM
Former Workshop Owner
For that kind of money, I'd be leary. With all the weight it is going to support, I would rather see what I am getting. Besides, what you save in cost will most likely be spent on shipping.
Also, if you are going to support a straight 6, you might want to make sure that it is long enough to remain stable. What works fine for a small block V8, might not be ideal for a longer, maybe even heavier straight 6.
Just my opinion.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#158469 11/02/2006 4:23 AM
you can find a stand at most parts stores that will hold 1000 lbs for about 60 bucks. If you want a wider "stance" consider buying one with square tubing and then add a bigger, or smaller, tubing to the existing tubing on the inside or the outside. Heck, you could even drill hoses in and make it adjustable. This is also how a lot of guys make a rotisserie for holding the bodies for blasting etc. This is just to get your gears turning!!!
#158470 11/02/2006 4:51 AM
4 wheels is better than three. Can't tell you how many times I almost dumped an engine on my old 3 wheel stand. I think Blackhawk make a nice, heavy-duty wide-stance stand.
Looks like Northern Tools has some neat stuff.
#158471 11/02/2006 3:48 PM
I bought one from harbor frieght that had fold up legs. Delivered for around $110. Very sturdy and can hold the weight. I have a fully dressed Olds 350 Rocket on it now.
http://da.harborfreight.com/cpisearch/web/search.do?keyword=engine+stand
#158472 11/02/2006 9:05 PM
I've used a couple of three wheelers for engines and currently have my 4t6 frame mounted on them. It works fine as long as you have a couple people flipping frame. Four wheels and a wider stance would help in either situation. Pics below
Dan
http://rides.webshots.com/photo/2951450480071274430qeOjmO
#158473 11/02/2006 9:07 PM
Junior Member
Junior Member
Thanks guys, I guess you get what you pay for is the truth. I'm looking at a 1500lb folding stand at Northern Equip for around $90 + shpg. It is 4 legged and looks pretty sturdy and I've had good luck dealing with them in the past. I like the folding design as there's not much room in my shop as it is.
Thanks again!
#158474 01/20/2007 10:28 PM
I bought a enigne hoist that came with an engine stand as a kit for just under $200.00 at Kragens. It worked great and the stand had four wheels. Im satisfied.
#158475 01/24/2007 7:22 PM
I bought mine from O'Reilly for about $50. It has 4 wheels and works great.
Dennis
#158476 02/24/2007 5:27 AM
I tried to find one that would let me cradle and run a 235 engine. Wound up buying some 2" square tubing, steel casters and fabricating my own. Have about $75. bucks in materials in it. Have a pic in my "Tips and Tricks Webshot album.
I just retrieved my rebuilt 235 yesterday and although I had to make a couple "adjustments" it provides me with a sturdy platform with great access. If anyone is interested, I can provide the dimensions.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Moderated by  MNSmith
