| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Hi All, Today was my 1st long run with my 52 Chevrolet 2 ton (Schuyler). My buddy and I made a 40 mile round trip to a landfill and I had about 1500# of load. All went well except 2 issues: When we arrived, I shut the old boy off, and there was just not enough oomph to get the starter to kick it back over. I am wondering if the fact I am still running on a 6 volt system coupled with the fact that I had lots of compression built up after the trip was factor. I am thinking if I convert to a 12 volt system this problem may be eliminated. I have heard there may be some sort of a converter that eliminates the need for replacing everything 6 volts - in other words it only sends 12 volts to the starter. Any ideas there??? Secondly, anyone ever had any experience with the the tranmission thrust washers? I am hearing a clattering in the transmission and am thinking and have been advised this may be the issue. Hope to hear from you Bolters. Sam the Meat Man 1952 2 ton Chevrolet - Schuyler
sam
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Could be the timing is just a tad fast. Or points slightly off. If the cables are big enough for the 6 volt, it should start reliably.
If it sounds like it grunts while trying to start hot, then the timing may be just a little fast. Might back it off a little and see how it does then. Be sure and check the point adjustment too, cause this also will affect the timing.
Good luck. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Converting the starter to twelve volts would just be masking the problem. Compression does not build up as you drive. As was stated, check your timing. Was the ammeter showing a good charge as you were driving? A bad starter can be affected by heat, but that isn't often a problem on Chevy sixes because of the exhaust routing. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Biggest problem I've seen with these old trucks through out the years, if they are still 6 volt,& having starting problems, is the original larger battery cables have been replaced with the skinny modern 12v cables, which won't do the trick. You need 2/0 cable. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by Sam the Meat Man: Secondly, anyone ever had any experience with the the tranmission thrust washers? I am hearing a clattering in the transmission and am thinking and have been advised this may be the issue. Hope to hear from you Bolters. Sam the Meat Man 1952 2 ton Chevrolet - Schuyler Does this truck have a PTO and what are the chances that it's engaged? I've forgot to shift mine out before and got an unusual noise. I also agree on backing the timing up some, after having the battery load tested, Scott | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | one thing you can try, my grandpa told me was to put an 8 volt battery in. he said they used to do that on his dad's farm, it cranked better and was a little stronger, i don't know if you can still buy 8 volt or not. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Eight volt batteries are just another bandaid that works OK on tractors, but not good on anything with lights because they blow pretty quickly. Fix it right. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I had an 8V batetry in my 53' GMC years ago and it was never satisfactory. The battery was never carged prpoerly by the 6V generator. It was a Delco Marine battery in otherwise good condition. I replaced it with a standard design 6V battery from a tractor supply comapany and never had another starting problem. So obviously I do not recommend 8V on a 6V system. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | As others have said, be sure that you have proper gauge cables. I had exactly the same symptoms with my 51 half ton, original 6 volts. Wouldn't start after a good run. It turned out all I had to do was clean the cables and engine ground strap connections. Haven't had a problem since I did that several years ago and the six volt system starts like a champ every time. Even if they don't look too bad clean them anyway, before you contemplate changing anything. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Sam the meat man a while back you were concerned the truck wouldn't run but 35mph. did you change anything or just press a little harder on the pedal? Glad to see you made it down the road. | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | I didn't change a thing- for now I am going to be content with 35-38 mph. Down the road a piece I aim to put a higher speed rear end in the old boy. Thanks for all your imput, I am going to change the timing back a tad and see what happens, also I will make sure those cables are the correct size. Sam
sam
