11 members (Peggy M, klhansen, Wayne67vert, 52Carl, Hotrod Lincoln, Forty9, walter74, HandyAndy, cmayna, 55shaker, TPR57C),
138
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | what does it cost to register a 63 Chevy 2 Ton COE i don't really want to pay for comercial plates cause i hear thats real expensive but i'm thinking about Farm Plates but then what do i do if i want to go out of state? so i really don't know what i'll end up doing but i'm still contemplateing if i'm going to buy the truck or not thanks Nate | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Check with MN-DOT or wherever you purchase the plates. Many states only require you to declare a GVW and will sell a plate accrdingly. If you never haul anything then it shouldn't be more than a pickup or so but the county or State can give you the correct answer. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I had some real go rounds with the DMV and even better was the insurnace companies,... If you register it as a collector vehicle, you'll have some limitations, but it sure beats paying gross tonnage! Collectors insurance is also alot cheaper 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | In Iowa, you pay by the ton. I licensed mine for 6 ton for about $125.00 a year. I figure that's cheap compared to the fines if you don't have the tags, Scott | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I believe for farm use, it goes by gross weight; and if I'm not mistaken, I think you can also buy just part of the year, since farming is seasonal. I don't recall all of the details. Since mine are just big boy's toys, I put collector plates on them. $25.00, and you only have to do it once!! | | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | In Maine you can register anything as an "antique" if it's over a certain (25?) number of years old. Supposedly just for parades, but if it's in decent shape the only reason the police stop you is to look at your rig. | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | you could also register it as an RV. and as farming, you can designate to use it only a certain amount out of the year | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i'm gona be making the truck into a flatbed bout 24 foot long so its gona be hauling stuff mainly just cars/trucks those are the plans i have so i don't know how some of them ideas will work if i'm going to be hauling Nate | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Here in WA. tags and tonnage are separate. On the dump I buy tonnage monthly. If you plan on using it for business talk to some local businesses doing the same thing. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Nate, are you hauling commercially, or just to parades and shows and such? If the latter, you could probably get by with collector plates. I even hauled a load of crushed rock with mine, and nobody bothered it. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | truck plate info collector plate info My suggestion to you is to find a "year of manufacture" plate. It's actually registered as a collector, but it's not so conspicuous. My '48 2ton has 1948 Minn. plates on it.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | It is realy hard to say. Things are so differant from state to state. | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | Rich, i do plan on hauling with the truck mainly just for my own use won't be used for a business or anything like that but mainly just hauling cars or the occasionaly load of scrap iron farm plates would work but i would like to be able to drive the truck out of the state
Keith, i could get ahold of plates for '63 year but i need ones for a 2 ton truck i don't think i could take 63 plates off a 63 1/2 ton and slap them on a 63 2 ton but then again i'm not really sure how that works
thanks for all the help guys Nate | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Originally posted by OldIronChevy: Rich, i do plan on hauling with the truck mainly just for my own use won't be used for a business or anything like that but mainly just hauling cars or the occasionaly load of scrap iron farm plates would work but i would like to be able to drive the truck out of the state
thanks for all the help guys Nate Best thing you can do is look up the laws concerning the use & restrictions for collector vehicles in your state & then call the DMV & ask a few pointed questions. In WA if you register as a collector vehicle, the only thing you can haul is butt, I wanna use it to haul my hot rod & the occasional odd things, hence why I registered mine regularly. However I had to get a commercial registration due to the gross tonnage and that kinda hurt. Better yet was the insurance, most copmpanies I talked to wouldn't insure something like my beast & I eneded up getting business insurance through Farmers. It's not bad, but could be better. Good thing is I can haul whatever I want, for myself or for profit, and my truck AND the load are covered. Been a real headache, but once it's done & overwith, not such an issue. As for the plates, truck plates are truck plates in most states. Another question for the DMV.  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | With my 38 I registered it historic no wieght on it. With the 48 I registered it farm use no wieght limit but was restricted to roads adjacent to farm. Nobody ever bothered me I ran about 25 mile radius. DOT has gotten more pig headed now though always out trying to raise more revenue. There was a insurance co advertising in Wheels of Time said you could haul your own vehicles and be covered it did not clarify how to tag them. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Nate, whereabouts in Minnesota are you located? | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | Winthrop, its pretty much right between Hutchinson and New Ulm | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Hey Nate, my '48 is a 2 ton and I have no idea what the '48 plates are originally from, I bought them an an antique store in Alexandria. I resistered my truck as a collector, didn't tell them the GVW, I just told them make and model, 1948 Chevrolet Loadmaster. The best advice when dealing w/DMV is if they don't ask, you don't tell.
By the way, I had my radiator re-cored at that radiator shop over in Arlington. Pretty spendy but he did a beautiful job.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Originally posted by OldIronChevy: Winthrop, its pretty much right between Hutchinson and New Ulm I know exactly where you're at. I get through there once or twice a year. We'll have to try and hook up sometime. I'm just East of Mankato. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Any one out there from massachusetts? How did you register yours? I thought about antique plates but there are alot of restrictions.Don't know how well they are inforced. commercial plates will cost a fortune here with insurance. I don't know if I have to go with commercial plates due to weight the tag says 20,000 lbs.I am only using it for personal use. Most people around here don't even know what a C50 is. I haven't talked to my insurance agent yet but I have 4 cars with him now so he will have to get inventive or I'll be shopping for new insurance for all of them.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | O.K. Nate, I lied. :rolleyes: You got me curious as to just how I registered my truck. I just found my registration form and this is how I registered, along with the fees I was charged. I was lucky on the sales tax part, because my truck was owned by a previous family member, therefore considered a "gift", because no money exchanged hands. It's registered as 1948 Chev. 2-ton truck. (I can't believe I told them 2-ton, I don't remember that.) It has "YOM" (year of manufacture) plates, and because of the year falls into the catagory of "classic". The fees are as follows: -plate reg. fee $25.00 -s.p.v. fee $ 3.50 -transfer fee $ 5.50 -m.v.transfer fee $10.00 -county fee $ 8.50 The collector/classic/pioneer class of vehicles are to be operated solely as collector items, and not used for general trasportation. That is taken right from the MN-DMV website. The only problem I see is that you want to be able to operate out of state. I have a '67 1/2 ton w/collector plates, I've pulled a trailer full of scrap to Mankato with it, and hauled materials from Menards, and used it as a daily driver for about a year, and was never qustioned about it once. But, I've never hauled anything out of state with it. I guess I've never heard of anyone being hassled about over using a collector vehicle. I don't think this is one of the laws that is strictly enforced here in our land of 10,000 lakes. But you might get questioned out of state. What I would do is call a liscense office, other than the one you plan on doing your registration at, and ask them what is best. Keep in mind that farm plates can be paid for quarterly if that better suits your needs. That's just my thoughts.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Hey Pete -- I hear the Lincoln County Sheriff is a closet Stovebolter... John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | Pakrat48 i took a radiator to that shop in arlington also but the said it has holes all over and needs to be recored witch was like 250 so i had to pass but the owner seems like a real nice guy, he tried to see if he could piece one together to keep the cost down he understood my money situation so i'll definately take my work there i'll definatly have to look into that year of manufacture thing i don't really need it to operate out of state but i would prefer it to be able to drive out of state
Rich we'll have to figure something out sometime but i'm out in wisconsin now going to school so it'll be a little bit before i'm back at home for good | | |
