4 members (Steelonsteel, TooMany2count, 6inarow, klhansen), 86 guests, and 1 robot.
Topics128,035
Posts1,055,552
Members48,425
#147420 07/12/2006 5:18 PM
I recently acquired a 1950 1 & 1/2 dual rear wheel big bolt in too good a condition to do anything but fix up a little and drive. It looks like it had a stake bed on it at one point. It was used the last number of years as a water tanker. It had nothing on it when I got it.
Does anyone have a source for diagrams and pictures of a period bed for this truck. I would like to get it close to "as deivered" condition as possible. Different theme beds are OK. Also factory, aftermarket or custom OK.
Thanks! Jim
Jim
Good luck with your project!
This is what the Factory Stake Bed, would look like, http://cgi.ebay.com/ebaymotors/eBayISAPI.dll?ViewItem&item=4644740314
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#147422 07/13/2006 12:37 AM
Many were ordered as Cab and chassis witth the cargo or speciality body added later
#147423 07/13/2006 12:52 AM
Jim,
This may not be what you are thinking of, but If you look in the Gallery under 55.1st big bolts, you will see my 4400.
It had an old Ford flatbed on it when I got it, and I built a new 12' bed for it soon after.
I purchased rails, corners, stake pockets and cross rails separately from a manufacturer in Los Angeles. To try and give it the authentic look, I ordered "round" corners...they almost look original.
The factory bed had no headboard (I think), but I built one for mine. Granted, this doesn't look entirely stock, but gives you some ideas of what is out there.
The outfit in L.A., Fleming Metal will punch the side rails for stake pockets wherever you want. They also supply the inner pocket itself, AND stakes of varying lengths.
This stuff was surprisingly affordable, but I am closer to them than you are from a freight standpoint.
Stuart
Click on "my 48 Loadmaster" in my signature line to see an original grain bed that was outfitted on my truck. It's 12' long and looks right for a 1 1/2 ton,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
You may want to check out my 53 3/4 ton FACTORY stakebed in the gallery. Prev. owner cut off the top row of boards but what's there was the read deal.
1946 1/2-Ton Chevy
Trust me !, The Factory Stake Bed, looked like the picture I posted earlier. I've owned 3 of them.
Spanky Hardy
1950 GMC 250 1-Ton
Thanks for all the reference material guys. I don't know exactly which way I will go with it yet, but all the info you have given me me is now in my "book". Thx, Jim
Jim
#147428 07/21/2006 11:04 AM
Looking for a stake body too. It'd be helpful to know the dimensions? Did they come in different lengths, which I guess would depend upon the wheel base. For '48 2t. loadmasters, what were the w.b.'s? I'm going to check out a local steel fabricator that makes dump bodies to see if anyone who bought one pulled his stake body.
#147429 07/23/2006 10:50 AM
Jim???? if you're still looking for a bed?? i have a AD chassis with an original bed on it (with extention) that was converted into a hay wagon.... The deck boards are toast...but if you want to come get the rails???? you can have them
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
Michael,
Thanks for the great offer! I recently had back surgery and cannot drive that far... yet. Maybe someone else can take advantage of your offer.
Thanks, Jim
Jim
Pete/ME,
Check out this link for the info you need. 50/48 should be the same.
Link:
http://chevy.tocmp.com/chevyresto/50index.htm
Jim
#147432 07/24/2006 10:45 AM
rev383, Thanks guy, but about how far past the rear axle should the body extend?
#147433 07/24/2006 11:58 AM
Pete: the body length is dependant upon the wheelbase and the C/A (cab to axle). Measure it and I'll give you the proper body length.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
