1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | I recently acquired a 1950 1 & 1/2 dual rear wheel big bolt in too good a condition to do anything but fix up a little and drive. It looks like it had a stake bed on it at one point. It was used the last number of years as a water tanker. It had nothing on it when I got it.
Does anyone have a source for diagrams and pictures of a period bed for this truck. I would like to get it close to "as deivered" condition as possible. Different theme beds are OK. Also factory, aftermarket or custom OK.
Thanks! Jim
Jim
Good luck with your project!
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Many were ordered as Cab and chassis witth the cargo or speciality body added later | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
This may not be what you are thinking of, but If you look in the Gallery under 55.1st big bolts, you will see my 4400.
It had an old Ford flatbed on it when I got it, and I built a new 12' bed for it soon after.
I purchased rails, corners, stake pockets and cross rails separately from a manufacturer in Los Angeles. To try and give it the authentic look, I ordered "round" corners...they almost look original.
The factory bed had no headboard (I think), but I built one for mine. Granted, this doesn't look entirely stock, but gives you some ideas of what is out there.
The outfit in L.A., Fleming Metal will punch the side rails for stake pockets wherever you want. They also supply the inner pocket itself, AND stakes of varying lengths.
This stuff was surprisingly affordable, but I am closer to them than you are from a freight standpoint.
Stuart | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Click on "my 48 Loadmaster" in my signature line to see an original grain bed that was outfitted on my truck. It's 12' long and looks right for a 1 1/2 ton, Scott | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You may want to check out my 53 3/4 ton FACTORY stakebed in the gallery. Prev. owner cut off the top row of boards but what's there was the read deal. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Trust me !, The Factory Stake Bed, looked like the picture I posted earlier. I've owned 3 of them. | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Thanks for all the reference material guys. I don't know exactly which way I will go with it yet, but all the info you have given me me is now in my "book". Thx, Jim
Jim
| | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | Looking for a stake body too. It'd be helpful to know the dimensions? Did they come in different lengths, which I guess would depend upon the wheel base. For '48 2t. loadmasters, what were the w.b.'s? I'm going to check out a local steel fabricator that makes dump bodies to see if anyone who bought one pulled his stake body. | | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Jim???? if you're still looking for a bed?? i have a AD chassis with an original bed on it (with extention) that was converted into a hay wagon.... The deck boards are toast...but if you want to come get the rails???? you can have them Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Michael,
Thanks for the great offer! I recently had back surgery and cannot drive that far... yet. Maybe someone else can take advantage of your offer.
Thanks, Jim
Jim
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Pete/ME, Check out this link for the info you need. 50/48 should be the same. Link: http://chevy.tocmp.com/chevyresto/50index.htm
Jim
| | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | rev383, Thanks guy, but about how far past the rear axle should the body extend? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Pete: the body length is dependant upon the wheelbase and the C/A (cab to axle). Measure it and I'll give you the proper body length. | | |
