4 members (Jay R, Eisenholtz, rick46ia, Shardean), 92 guests, and 2 robots.
Topics128,023
Posts1,055,366
Members48,420
#135973 11/08/2006 10:23 PM
I have a 66 C10 with 283 2 bbl & 3speed and am thinking of upgrading to add a little snazz and couple hp.
Plan is change over to 4 bbl with alum intake and maybe holly carb.
This has manual choke. any thoughts on this? also considerations on the egr. What should I buy here.
Comments welcome from the experts.
Gary
GS
#135974 11/08/2006 11:20 PM
Hi Gary
The Edelbrock Performer manifold would be a good choice.If egr isn't required by law in your state I wouldn't bother.Keep in mind you will want to change the cam too.A 4bl on a 2bl cam wouldn't be all that good.
#135975 11/09/2006 12:16 AM
Unless you're going to drag race, I would opt not to use the Holley. Find a Edelbrock or a Quad to rebuild instead. Just my opinion but Holley's are a pain for the street,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#135976 11/09/2006 5:10 PM
Edelbrock
#135977 11/09/2006 5:39 PM
buy the edelbrock kit, comes with a cam, intake and carb... works very well...
Another quality post.
Real Trucks Rattle
#135978 11/09/2006 11:27 PM
I put an Edelbrock 600 cfm on my 283. Also an RV cam. Works great!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#135979 11/10/2006 10:12 PM
Hey guys. Thanks for the great tips.
Gary
GS
#135980 11/19/2006 7:48 AM
Keep the carb on the smaller size. Too big will just suck gas and have poor performance
500 to 600 CFM is more than big enough for a 283.
#135981 12/03/2006 7:45 AM
Rustyrod has the right idea-the kit is designed to work together. And the main problem with Holley carbs is that they're so adjustable,and being tinkerers by nature,rodders tend to adjust a lot of stuff they don't know the actual function of. I talked to a tech at the Holey Carb trailer at the races a couple of years ago,and he said 98% of what he had to do to "un-f**k" the Holley carbs brought to him consisted of adjusting EVERYTHING back to specs and replacing the occasional power valve or accelerator pump. Personally,I've never had any problem with Holleys except I could never get better than 10 miles per gallon with one.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#135982 12/03/2006 6:24 PM
Riding in the Passing Lane
The Edelbrock manifold is a good package. If you want to save money & can rebuild a carb yourself you can find a Q-jet at a swap meet or pull your own parts lot real cheap. You can put in an electric choke if it doesn,t have one.
1972 Chevy c10 Cheyenne Super
#135983 12/13/2006 8:18 AM
Q-jets are perfect for 283's, that's what they were designed for originally.
Paint & Body Shop moderator
#135984 12/15/2006 8:38 PM
Apprentice
Apprentice
I'm putting an edlebrock c-26 dual quad intake with offy cross ram adaptors and two 600 cfm edlebrock AFBs on my 283...but I'm totally nuts.
Also got a comp cam, roller tip rockers (1.5 intake and 1.6 on exhaust), new timing set, reworked power pack heads with 1.82 intake valves and hardened exhaust seats. I plan on using a progressive linkage and will dial in the carbs with new rods and jets.
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
#135985 12/25/2006 6:44 AM
I've a couple of years experience with this stuff and find that I get more bang for the buck with a free flowing exhaust as the first step. Then second is a cam that will get the F/A mixture moving into and out of the cylinders. Don't overdo the cam. This is a truck and you don't want to kill the low end torque. Now if you find that your starved for F/A then upgrade the intake.
