5 members (1955 1 Series, mason86, Wayne67vert, Peggy M, Hotrod Lincoln), 85 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#133994 03/08/2006 3:27 AM
7
Junior Member
Junior Member
7 Offline
I see rebuilt Mustang II power racks for sale on ebay. Can I hook up a GM pump to one and get proper variable pressure,"more pressure at idle for parking"? Or should I bite the the bullet and pay the big bucks for the Flaming River package?
#133995 03/08/2006 4:51 AM
If you want to use a rack, you'll want something brand new and fresh. GM pumps are known for getting weak and making the fluid "metallic" and that's the last thing you want in a P/S rack is fine metal particles. If it's offered as a system, I would buy it that way,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#133996 03/08/2006 12:58 PM
7
Junior Member
Junior Member
7 Offline
Thanks Scott,I'm sure I'll be happier that way in the long run. Looks like it will be approaching $1000 by the time I'm done.
#133997 03/08/2006 3:22 PM
i have been using a gm pump on an amc pacer IFS and it overboosts the steering ( too light ) i bought a new valve which helped some. there is adjustable kit but it is pricey, but you can adjust down to no power input. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#133998 03/09/2006 2:04 AM
mullins/ididit offer a pressure reducing kit i bought one yrs ago still have not installed yet do to fact truck not done yet it consisted of a spring and sone washers and a wrench the guy from mullins told me to start with two washers and go from there. said to add until i got the right amont of "road feel" that i wanted. kit was only about $20.00. i'm also running a pacer ifs with a gm pump. i'm sure they probly still have them.
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#133999 03/09/2006 4:11 AM
been running a stangII front system for 6 years no problem. I took the front end out of a junk yard and then used the old ones as cores for rebuilt ones from local parts store. Does find, perhaps a "little" touchy but if you drive fast you only need to aim it anyway grin
#134000 04/21/2006 9:17 PM
Z
Z Offline
I have set my GM pump pressure many times, I beleive the problem is dual, a constant pressure pump and a 2 1/2 turn lock to lock rack. The manual rack's are 4 turn LTL. My steering is still very responsive (touchy). I would like to know if the Flaming river power rack kit is any better with a variable pressure pump, I beleive they say pressure drops with increased RPM. Anyone try Flaming River power rack KIT? Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
