| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | I see rebuilt Mustang II power racks for sale on ebay. Can I hook up a GM pump to one and get proper variable pressure,"more pressure at idle for parking"? Or should I bite the the bullet and pay the big bucks for the Flaming River package? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you want to use a rack, you'll want something brand new and fresh. GM pumps are known for getting weak and making the fluid "metallic" and that's the last thing you want in a P/S rack is fine metal particles. If it's offered as a system, I would buy it that way, Scott | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Thanks Scott,I'm sure I'll be happier that way in the long run. Looks like it will be approaching $1000 by the time I'm done. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have been using a gm pump on an amc pacer IFS and it overboosts the steering ( too light ) i bought a new valve which helped some. there is adjustable kit but it is pricey, but you can adjust down to no power input. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | mullins/ididit offer a pressure reducing kit i bought one yrs ago still have not installed yet do to fact truck not done yet it consisted of a spring and sone washers and a wrench the guy from mullins told me to start with two washers and go from there. said to add until i got the right amont of "road feel" that i wanted. kit was only about $20.00. i'm also running a pacer ifs with a gm pump. i'm sure they probly still have them. 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | been running a stangII front system for 6 years no problem. I took the front end out of a junk yard and then used the old ones as cores for rebuilt ones from local parts store. Does find, perhaps a "little" touchy but if you drive fast you only need to aim it anyway  | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I have set my GM pump pressure many times, I beleive the problem is dual, a constant pressure pump and a 2 1/2 turn lock to lock rack. The manual rack's are 4 turn LTL. My steering is still very responsive (touchy). I would like to know if the Flaming river power rack kit is any better with a variable pressure pump, I beleive they say pressure drops with increased RPM. Anyone try Flaming River power rack KIT? Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
