| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Stovebolters I am restoring to original a 1946 Chevy 1-ton model DS pickup with a 9 foot bed. When I got the truck the bed had both sides, front bed panel and the tailgate and two cross members. I have the new wood for it, bolt kit and the bed strips. Need to know how many of the cross members are needed and any mounting blocks etc. Photos? Thanks Brian | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Brian, I'd suspect 4 cross sills needed and wood blocks probably 2 1/4" square......not sure but just from past experiences.
....but, check out the Mar-K here on the bolt. They are a sub forum in the "bed" forum. There maybe an assembly page you can find or contact Mar-K. They are nice folks, good quality and right here in the good ole USA. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I don't know about '46, but the AD panel express had the same body to frame mounts and cross sills as the panels and 'burbs. You could check with that forum as well for input.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Just looked at mine, which is original. There are four main cross members and two low profile ones that span between the wheel wells. My guess is so they don't rub on the tires. | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Thanks 641 Workmaster That helps. I do have the two regular ones and two of the low profile ones. Any wooden blocks? Brian | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | No blocks. Right on frame. The "regular ones" are between the main ones between the wheel opening. There were no holes in the frame below them to indicate they had ever been "braced" to the frame. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the shorter cross sills between the wheel wells are 'stiffeners' that don't contact the frame, they just hang off the floor
Bill | | |
