2 members (Snowman51, Steelonsteel), 105 guests, and 2 robots.
Topics128,118
Posts1,056,646
Members48,450
old truck heaven
old truck heaven
Hi Stovebolters
I am restoring to original a 1946 Chevy 1-ton model DS pickup with a 9 foot bed. When I got the truck the bed had both sides, front bed panel and the tailgate and two cross members. I have the new wood for it, bolt kit and the bed strips. Need to know how many of the cross members are needed and any mounting blocks etc. Photos?
Brian
Brian, I'd suspect 4 cross sills needed and wood blocks probably 2 1/4" square......not sure but just from past experiences.
....but, check out the Mar-K here on the bolt. They are a sub forum in the "bed" forum. There maybe an assembly page you can find or contact Mar-K. They are nice folks, good quality and right here in the good ole USA.
I don't know about '46, but the AD panel express had the same body to frame mounts and cross sills as the panels and 'burbs. You could check with that forum as well for input.
Dave Baird
1951 Chevy 3803
Just looked at mine, which is original. There are four main cross members and two low profile ones that span between the wheel wells. My guess is so they don't rub on the tires.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
old truck heaven
old truck heaven
Thanks 641 Workmaster
That helps. I do have the two regular ones and two of the low profile ones. Any wooden blocks?
Brian
No blocks. Right on frame. The "regular ones" are between the main ones between the wheel opening. There were no holes in the frame below them to indicate they had ever been "braced" to the frame.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
the shorter cross sills between the wheel wells are 'stiffeners' that don't contact the frame, they just hang off the floor
Moderated by  Dusty53
