I've just completed switching everything over from 6 to 12 volts. All I need to do is connect the yellow DA plug wire to the ignition switch. All instructions I've seen says to connect it to the IGN post of the switch. There are 3 posts on the switch and I cannot find any markings. One post is empty, one has a single wire which I believe may be going to the + side of the coil and the last post has 2-3 wires connected I believe from the light switch, ammeter guage and who knows what else. Which one do I connect the DA wire to ??
Craig
