| | | Forums66 Topics128,269 Posts1,058,404 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Based on advice in this thread I went back and re-coated the few items I previously treated with phosphoric acid. When that surface coating loosened up I wiped the parts down right away and now have nicely coated parts without the rough surface coating they had before. They could be primed right away now without a lot of prep. That tip of re-coating saved me a lot of prep work. The big thing I was missing was keeping the surface wet and wiping it off while still wet. There is a lot of advice suggesting leaving it on overnight. I think some of my confusion comes because it is okay to leave it overnight or even soak rusty metal. Stripped shiny metal needs only a few minutes and then wiped clean. Many of my parts are going to have some areas of rust and some shiny metal. I am now comfortable enough using phosphoric acid to start treating my body panels as I finish each one and will start priming when I have a few pieces ready. Thanks to all who contributed to this thread.
Chuck | | | |
Entire Thread
phos acid, how should it look when done
| dgallagher | 06/10/2009 1:22 AM |
Re: phos acid, how should it look when done
| Wisner955 | 06/10/2009 1:37 AM |
| dgallagher | 06/10/2009 1:52 AM |
| BIG CHEVY 3600 | 06/10/2009 2:26 AM |
| dgallagher | 06/10/2009 2:42 AM |
| BIG CHEVY 3600 | 06/10/2009 2:53 AM |
| dgallagher | 06/10/2009 3:02 AM |
| Czechman | 06/10/2009 4:00 AM |
| dgallagher | 06/10/2009 4:20 AM |
| BIG CHEVY 3600 | 06/10/2009 2:43 PM |
| 62 mark | 06/12/2009 12:54 AM |
| Czechman | 06/12/2009 11:58 AM |
| BIG CHEVY 3600 | 06/12/2009 2:17 PM |
| ScottGMC40001964 | 06/20/2009 12:39 AM |
| Flxible | 06/20/2009 2:56 AM |
| Czechman | 06/20/2009 12:10 PM |
| ScottGMC40001964 | 06/22/2009 4:08 AM |
| Flxible | 06/22/2009 4:32 AM |
| Czechman | 06/22/2009 1:05 PM |
| DennisM | 06/22/2009 2:33 PM |
| Hookalatch | 06/22/2009 4:50 PM |
| Flxible | 06/22/2009 5:44 PM |
| Czechman | 06/22/2009 10:39 PM |
| Flxible | 06/22/2009 11:25 PM |
| Hookalatch | 06/24/2009 3:34 AM |
| Czechman | 06/12/2009 11:54 AM |
| Modelman | 06/24/2009 1:40 PM |
| Flxible | 06/24/2009 3:54 PM |
| dgallagher | 06/30/2009 4:36 AM | |
