| | | Forums66 Topics128,184 Posts1,057,196 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I'm not sure if this would be the same application for your AD, but you can look into it. I have a '46 3/4ton with the 15" 8-lug split rim. I was told to look for a mid-80's K20 Chevy 16" rim. So I stopped at the local junkyard and they had a set. Most yards have them in a wheel rack or you can unbolt them off the junker. I paid about $30/rim. The look is almost identical to my originals except for a few buldges in the hub for the newer style hubcaps. They have a 4" backspace and are 6.5" wide. I've mounted one up to both the front and rear and have no clearance problems with a 235/85/16 over the rear brakes or the front tie rod end.
To me, it's an easy and cheap update. Locate one at a yard, drive over, and see if they'll let you fit one up to your truck so you're not out $30. I wouldn't think it would be to hard to find one rim and try it.
As a side note, I've priced both bias and radials. I thought a no-name bias would be cheaper but in the end a name brand radial is the same amount. | | | |
Entire Thread
1950, 3604 - My old gal is bouncing her back end around!!!
| Denny Graham | 07/31/2007 3:26 PM |
Re: 1950, 3604 - My old gal is bouncing her back end around!!!
| Grigg | 07/31/2007 3:52 PM |
| mike1951 | 07/31/2007 4:25 PM |
| Builder | 07/31/2007 5:53 PM |
| hotshoe36 | 07/31/2007 6:17 PM |
| Hotrod Lincoln | 07/31/2007 6:37 PM |
| mike1951 | 07/31/2007 6:54 PM |
| Denny Graham | 07/31/2007 10:54 PM |
| BIG CHEVY 3600 | 08/01/2007 12:13 AM |
| 1958GMCnut | 08/01/2007 2:46 AM |
| hotshoe36 | 08/01/2007 2:55 AM |
| Achipmunk | 08/01/2007 3:05 AM |
| Grigg | 08/01/2007 3:44 AM |
| Denny Graham | 08/01/2007 6:27 AM |
| Grigg | 08/01/2007 6:36 AM |
| 1958GMCnut | 08/01/2007 7:55 AM |
| Denny Graham | 08/01/2007 11:31 AM |
| Grigg | 08/01/2007 1:49 PM |
| Shellology | 08/01/2007 3:40 PM |
| Denny Graham | 08/02/2007 4:22 AM |
| 10 micron | 08/02/2007 6:17 PM |
| Denny Graham | 08/03/2007 3:21 AM |
| bigmacdaddy | 08/03/2007 3:25 AM |
| Denny Graham | 08/03/2007 12:09 PM |
| Hotrod Lincoln | 08/03/2007 3:31 PM |
| hotshoe36 | 08/04/2007 8:30 PM |
| Denny Graham | 08/05/2007 4:10 AM |
| hotshoe36 | 08/05/2007 6:21 AM |
| Denny Graham | 08/05/2007 2:00 PM |
| Hotrod Lincoln | 08/05/2007 2:54 PM |
| hotshoe36 | 08/05/2007 4:09 PM |
| Denny Graham | 08/05/2007 7:44 PM |
Anonymous
| 08/05/2007 8:32 PM |
| Grigg | 08/05/2007 9:26 PM |
| Hotrod Lincoln | 08/06/2007 4:13 PM |
| hotshoe36 | 08/06/2007 4:25 PM |
| Builder | 08/06/2007 4:26 PM |
| 641Workmaster | 08/06/2007 4:42 PM |
| Hotrod Lincoln | 08/06/2007 9:00 PM |
| Denny Graham | 08/06/2007 9:44 PM |
| hotshoe36 | 08/06/2007 10:49 PM |
| Hotrod Lincoln | 08/06/2007 11:03 PM |
| 641Workmaster | 08/07/2007 12:32 AM |
| Denny Graham | 08/07/2007 2:16 PM |
| Hotrod Lincoln | 08/07/2007 3:35 PM |
| tlorber | 08/09/2007 6:40 PM |
| Denny Graham | 08/10/2007 3:20 AM | |
