Winter is Coming
pics. The shifter brackets holes were too small for the plastic bushing so those got drilled larger. Much tighter shift than before. I need to figure out how to get the speedometer working. Looks plugged . I have everything for the speedo. Any methods for removing that plug?
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
