| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I believe the ball pivots have a straight shank that's peened on the back side. It will probably be necessary to taper ream the holes in the steering arms to fit the taper on the bolt-in tie rod ends. Victor Machinery Co. should have the proper angle taper reamer for that job. www.victornet.comJerry
