0 members (),
138
3
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Get a can of KROIL!! Pull the spark plugs and soak the top of the cylinders. Pull the rocker cover and soak the rockers with KROIL as well as the lifters and lifter valleys. Let it set for a few says up to two weeks. Check it daily and try to spin the crank with the fly wheel. Back and forth movement helps to break it loose. KROIL works better than any other product I've used. There are many write ups on this forum concerning engines being stuck. You can get KROIL on the web. They have a complete website.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
Entire Thread
Is the motor frozen, or just stuck? "it ran when I parked it there"
| Patagoniadave | 02/28/2017 3:27 PM |
Re: Is the motor frozen, or just stuck? "it ran when I parked it there"
| JW51 | 02/28/2017 3:43 PM |
| fixit1958 | 02/28/2017 4:12 PM |
| Patagoniadave | 02/28/2017 4:27 PM |
| panic | 02/28/2017 4:36 PM |
| Hotrod Lincoln | 02/28/2017 5:14 PM |
| Patagoniadave | 02/28/2017 5:44 PM |
| fixit1958 | 02/28/2017 6:16 PM |
| Patagoniadave | 02/28/2017 6:37 PM |
| Justhorsenround | 02/28/2017 7:18 PM |
| Patagoniadave | 02/28/2017 7:27 PM |
| Hotrod Lincoln | 02/28/2017 8:06 PM |
| Volfandt | 02/28/2017 8:37 PM |
| Patagoniadave | 02/28/2017 8:45 PM |
| bartamos | 02/28/2017 9:02 PM |
| Patagoniadave | 02/28/2017 9:20 PM |
| bartamos | 02/28/2017 9:23 PM |
| Patagoniadave | 02/28/2017 9:30 PM |
| JW51 | 02/28/2017 10:38 PM |
| bartamos | 02/28/2017 11:06 PM |
| JW51 | 03/01/2017 12:29 AM |
| Hotrod Lincoln | 03/01/2017 1:01 AM |
| bartamos | 03/01/2017 1:09 AM |
| Hotrod Lincoln | 03/01/2017 1:22 AM |
| bartamos | 03/01/2017 1:28 AM |
| Patagoniadave | 03/01/2017 4:12 AM |
| Volfandt | 03/01/2017 2:17 AM |
| Hotrod Lincoln | 03/01/2017 4:35 AM |
| bartamos | 03/01/2017 5:37 AM |
| Patagoniadave | 03/01/2017 3:17 PM |
| Patagoniadave | 04/05/2017 7:24 PM |
| Hotrod Lincoln | 03/01/2017 5:46 AM |
| moparguy | 03/01/2017 2:42 PM |
| Volfandt | 03/01/2017 2:53 PM |
| Justhorsenround | 03/01/2017 3:34 PM |
| Patagoniadave | 03/01/2017 4:19 PM |
| Hotrod Lincoln | 03/01/2017 4:53 PM |
| yar | 03/01/2017 5:22 PM |
| bartamos | 03/01/2017 6:39 PM |
| Patagoniadave | 03/01/2017 7:25 PM |
| bowtietim | 03/02/2017 4:51 AM |
| Patagoniadave | 03/02/2017 2:53 PM |
| bartamos | 03/05/2017 6:14 AM |
| fixit1958 | 03/05/2017 3:00 PM |
| Patagoniadave | 03/05/2017 4:35 PM |
| Justhorsenround | 03/05/2017 5:27 PM |
| fixit1958 | 03/05/2017 5:40 PM |
| bartamos | 03/05/2017 6:20 PM |
| moparguy | 03/06/2017 4:22 AM |
| 52Carl | 03/08/2017 2:54 AM |
| moparguy | 03/08/2017 3:51 AM |
| Hotrod Lincoln | 03/08/2017 4:16 AM |
| Patagoniadave | 03/09/2017 3:19 PM |
| bartamos | 03/09/2017 6:58 PM |
| JW51 | 03/09/2017 7:19 PM |
| Patagoniadave | 03/09/2017 7:37 PM |
| JW51 | 03/09/2017 7:39 PM |
| Patagoniadave | 03/09/2017 8:03 PM |
| bartamos | 03/09/2017 7:40 PM |
| JW51 | 03/09/2017 7:44 PM |
| bartamos | 03/09/2017 7:53 PM |
| JW51 | 03/09/2017 8:10 PM |
| Volfandt | 03/09/2017 11:37 PM |
| JW51 | 03/10/2017 12:59 AM |
| bartamos | 03/10/2017 1:19 AM |
| fixit1958 | 03/10/2017 4:10 PM |
| Patagoniadave | 03/10/2017 4:38 PM |
| Mike B | 03/11/2017 5:49 AM |
| Patagoniadave | 03/12/2017 6:09 AM |
| truckernix | 03/12/2017 1:26 PM |
| Patagoniadave | 03/13/2017 3:09 PM |
| JW51 | 03/12/2017 3:17 PM |
| fixit1958 | 03/12/2017 3:51 PM |
| MikeE | 03/12/2017 5:22 PM |
| bartamos | 03/12/2017 5:51 PM |
| 52Carl | 03/13/2017 12:49 AM |
| Patagoniadave | 03/13/2017 3:07 PM |
| Patagoniadave | 03/13/2017 4:04 PM |
| Hotrod Lincoln | 03/13/2017 4:25 PM |
| Patagoniadave | 03/13/2017 4:34 PM |
| Justhorsenround | 03/13/2017 4:43 PM |
| Patagoniadave | 03/13/2017 4:57 PM |
| Hotrod Lincoln | 03/13/2017 4:48 PM |
| Patagoniadave | 03/22/2017 3:14 PM |
| Hotrod Lincoln | 04/05/2017 7:29 PM |
| JW51 | 04/05/2017 9:49 PM |
| Patagoniadave | 04/05/2017 9:57 PM |
| JW51 | 04/05/2017 10:11 PM |
| Patagoniadave | 04/05/2017 10:17 PM |
| Hotrod Lincoln | 04/05/2017 11:31 PM |
| JW51 | 04/06/2017 2:04 AM |
| Patagoniadave | 04/06/2017 3:28 AM |
| Patagoniadave | 04/25/2017 3:44 PM |
| truckernix | 04/25/2017 3:55 PM |
| Patagoniadave | 04/25/2017 4:15 PM |
| Patagoniadave | 04/26/2017 4:47 PM |
| Hotrod Lincoln | 04/26/2017 5:08 PM |
| Patagoniadave | 04/26/2017 5:32 PM |
| Howies551Ton | 04/27/2017 8:22 PM |
| Patagoniadave | 04/27/2017 8:37 PM |
| Hotrod Lincoln | 04/27/2017 9:23 PM |
| Patagoniadave | 04/27/2017 10:16 PM |
| Hotrod Lincoln | 04/27/2017 11:24 PM |
| Pre '68 Dave | 04/27/2017 11:53 PM |
| Patagoniadave | 04/28/2017 3:34 PM |
| Hotrod Lincoln | 04/28/2017 3:56 PM |
| Patagoniadave | 04/28/2017 4:44 PM |
| Hotrod Lincoln | 04/28/2017 5:25 PM |
| 52Carl | 04/29/2017 4:59 AM |
| Patagoniadave | 05/01/2017 4:01 PM |
| JW51 | 05/01/2017 5:50 PM |
| Patagoniadave | 05/01/2017 6:06 PM |
| Hotrod Lincoln | 05/01/2017 6:47 PM |
| Patagoniadave | 05/01/2017 6:52 PM |
| 52Carl | 05/02/2017 2:46 AM | |
